Valvesprings.....
Old Mar 1, 2008 | 10:23 AM
grinder11's Avatar
grinder11
Default Valvesprings.....
I have a set of AFR 225's. I ran Comp 921's for around 26,000 miles w/no issues. I understand that AFR has released a proprietary dual valvespring (Part# 8019, I believe) that is also supposed to be very good AND according to AFR shows about a 10-15 HP increase over the 921's. I have had some issues with broken valvesprings on these heads due to the heads being incorrectly set up when new, and with the amount of money, and also plain HARD WORK it takes to R&R one of these motors from a C5, I am somewhat reluctant to change brands away from Comp, as they worked great for nearly 30,000 miles, and I am only changing them out because that is a LOT of miles for a valvespring that endures +.600 lift. BUT, like you guys, I AM intrigued by gaining 10-15 HP, especially for a price that is lower than the 921's are going for, though not a lot less. It would seem that because AFR makes good stuff, and they do stand behind their products, their valvesprings should (and HAVE to be) also be good stuff. Has anyone had any experiences with these springs? Any idea who makes them for AFR? Please let me know. Thank you.
Old Mar 1, 2008 | 11:06 AM
WKMCD's Avatar
WKMCD
I think any claim of an HP increase is based on the assumption that your current setup is not maintaining valve control. That's not going to be the case with 921's. The 921's are one of the best springs out there. You can buy just the springs since you already have the Ti retainers and spring seats and save a couple of hundred dollars.
Comp 921's are the only springs I will run.
Old Mar 1, 2008 | 01:03 PM
vettenuts's Avatar
vettenuts
I would agree with the above as far as a hp gain. The 8019's are supposed to be excellent valve springs. I have a set on my heads on the workbench right now. Comp recently switched spring vendors (well, several months ago) and they ran into problems with the 918's, a few 921's had issues as well from what I read on other boards (I have no direct experience with this). I haven't heard of this issue recently so presumably the problems are resolved. If you go with the 921's, make sure you get them from a vendor who turns over a lot of stock and they haven't been sitting on the shelf for six months just in case there are still of few of the questionable sets floating around.
Old Mar 1, 2008 | 01:38 PM
chevy406's Avatar
chevy406
If you buy a set of Comp springs and are concerned with the batch number, just call their Engineering Department. I bought a new set of 918's that were prior to the revision. They sent me a set of the revised springs, and I mailed them back the ones I had. Competition Cams is a stand up company.
Old Mar 1, 2008 | 01:47 PM
vettenuts's Avatar
vettenuts
That's interesting, the new specs are closer to the PSI 1511's.
Old Mar 1, 2008 | 02:52 PM
OhioC5's Avatar
OhioC5
Which is the new batch number? Are the 918's only good up to .600?
Old Mar 1, 2008 | 04:17 PM
vettenuts's Avatar
vettenuts
New design is on the right in the photo.
Old Mar 1, 2008 | 06:00 PM
OhioC5's Avatar
OhioC5
Thanks, are they only good to .600 lift
Old Mar 1, 2008 | 09:17 PM
chevy406's Avatar
chevy406
Comp lists the upgraded 918's for .600" lift. It could go a little more, but I personally wouldn't do it.
As Vettenuts pointed out, the new design is the shiny silver color. They have now included a glass bead tumbling as a final stress relieve step, and that produces the new silver finish. I have about 8k miles on my 918 springs, and they are still good to go.
Old Mar 2, 2008 | 09:56 AM
grinder11's Avatar
grinder11
This thread is kinda going off topic. I AM NOT looking at the 918 Comp springs.....I AM looking for someone who has run the AFR #8019 springs, and whether or not they were satisfied with them. For those who may not know, the 8019's are somewhat unusual in that the inner spring is about 1/4" to maybe 5/16" longer than the outer spring. FWIW, if I remember correctly, the earliest 918 Comps were advertised as being capable of handling a lift of .625". But I have not seen this figure in several years now. I might add that I have seen, and I am still seeing, ads for the 921's that show a capability of BOTH .625" AND .650" lift!!! I wonder which one is right?
Old Mar 2, 2008 | 10:07 AM
vettenuts's Avatar
vettenuts
Your best source of information on the 8019's is really Tony Mamo. I know he has done a lot of testing on them personally and has stated many times how impressed he is with them on several boards I belong to. While I have them on my heads right now, I don't have any experience with them yet that will help you out.
Only thing I can offer is I did weigh them.
Spring: 95 gms
Retainer: 10 gms
Lock: 3 gms
Old Mar 2, 2008 | 10:24 AM
grinder11's Avatar
grinder11
Spring: 95 gms
Retainer: 10 gms
Lock: 3 gms
Thankyou. At least I have found someone that has actually installed tham and is running them....with no problems. I wonder what the Comp 921's weigh?
Old Mar 2, 2008 | 11:16 AM
ArKay99's Avatar
ArKay99
I just had a set of 8019's installed on my newly reworked AFR 205's. I have about 100 miles on them so I can't give you any impression of how they hold up in the long run. Observations are they are very stout. I believe 155lbs. seat at installed height and 435lbs open. They are good .660" inch. They are heat cycled or treated so they don't require a break in.
Tony did my heads for me and while we were specing the heads we talked about the springs. I used to have 8017's which a very much like the Patriot Gold's and Tony told me these were an improvement over them. I don't know of anyone breaking a Patriot Gold, but that doesn't mean it hasn't happened. I'm sure any spring could break.
I'm currently running them in my LPE 403 and have had no issues with them.
Old Mar 2, 2008 | 12:44 PM
grinder11's Avatar
grinder11
Thank you. I guess time will tell. I know the 921's are time proven, but I also see on the forum that Comp switched vendors for the 921's (Maybe all their valvesprings?) and there have been some issues since this happened. It's a shame when you have such a well respected product like these springs were, then change something so critical, such as the people who are making your product!! Then it goes sour. It is even more of a shame (Not to mention downright expensive!!) when people like you and I have to do the R&D on the product in question out in the field (On the road, actually!). I have a set of 8019's here ready to go, as per Tony's recommendation, and he did my 225's recently, as well. I guess after the spring issues I have had, I am a little gun-shy, that's all! Thanks again, and good luck with your 8019's!
To Valvesprings.....
