c6 shifter
Old Mar 1, 2008 | 11:08 AM
ecoman's Avatar
ecoman
Default c6 shifter
Is a stock C6 shifter better than the stock C5 or is it just the C6 ZO6 that is better?
Old Mar 1, 2008 | 01:15 PM
T_Vert's Avatar
T_Vert
I love my c6 shifter. Shorter, better looking **** and a bit tighter.
Dave
Old Mar 1, 2008 | 01:47 PM
ecoman's Avatar
ecoman
Dave
Is it a ZO6 or reg.C6?
Old Mar 1, 2008 | 01:52 PM
T_Vert's Avatar
T_Vert
I believe it is a regular c6
Dave
Old Mar 1, 2008 | 02:28 PM
20vette0107fatboy's Avatar
20vette0107fatboy
Dave
The C6 shifter is the same as the Z06 C6 shifter.Just did mine a couple months ago...WOW..what a diff.I love it
Old Mar 1, 2008 | 02:55 PM
ecoman's Avatar
ecoman
thanks for the info just bought one from a member can,t wait for better weather to try.
Old Mar 1, 2008 | 04:17 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
They are certainly different.
Old Mar 1, 2008 | 04:18 PM
vettenuts's Avatar
vettenuts
Gene,
Can you explain what the difference is? I have often wondered.
Old Mar 1, 2008 | 06:49 PM
DRR's Avatar
DRR
Pics and part #'s too...
Old Mar 1, 2008 | 09:57 PM
CF6873's Avatar
CF6873
I just bought a used C6 shifter from a forum member and installed it today. I drove the Z about 20 miles tonight and love it so far.
Old Mar 1, 2008 | 10:17 PM
blackconv's Avatar
blackconv
Originally Posted by vettenuts
Gene,
The C6 Z06 is hard mounted to the torque tube, and the C6 has rubber bushings where it mounts to the torque tube, same as C5. The C5 is actually a better shifter, it has bronze bushings in it's housing for the shaft to ride on, the C6 shifter shaft rides on seals only. The only difference between C5 and C6 is the angle and length of the lever.
Old Mar 2, 2008 | 02:59 AM
dieseldave56's Avatar
dieseldave56
Default 3 mounting bushings................
http://forums.corvetteforum.com/show....php?t=1861978 Gotcha show in his pictures the differences.
Both C5 and C6 have bronze shift box bushings.
Old Mar 2, 2008 | 06:48 AM
blackconv's Avatar
blackconv
That is the difference between Z06 and non Z06 (both C5 and C6), hard mounted (Z06) or rubber bushings (non Z06) to the torque tube. The bronze bushings that are missing in the C6 housing are internal, where the shift rod rides in the housing.
To c6 shifter
