HELP! car is bucking/hesitating
Old Mar 1, 2008 | 09:16 PM
Gorrella's Avatar
Gorrella
Default HELP! car is bucking/hesitating
I have a 03 Z06 and I just put the stock manifolds and cats back on after having LG long tubes with-out cats. The car ran fine with the LG's and no cats but when I put the stock system back on the car started bucking or acted like it was loading up with fuel at slow speeds when under a load. It did this for about 15 min. and stopped. But now when I try to accelerate hard the car starts to buck ( seems like its loading up with fuel and you can hear it popping in the exhaust system. ) I have unpluged the battery for the night but I dont think its going to help. If anyone has some input I would Appreciate it.
Old Mar 2, 2008 | 12:15 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds EXACTLY like you have an engine miss fire most likely related to a plug or wire issue. I would make sure that:
1. The plugs are not cracked. (Very easy to do)
2. A wire is not completly on the plug or coil.
3. A wire is damaged. They should read 250-750 ohms end to end
See if your check engine light (CEL) flashes when your exhibiting the problem.
BC
Old Mar 2, 2008 | 02:50 AM
gpracer1's Avatar
gpracer1
Number one cause after messing with header / exhaust replacement is cracked plugs.....followed by a close second is O2 sensors crossed, but thats usually only when putting headers on, since they are real close. I dont think that you can cross them with stock manifolds.
Old Mar 2, 2008 | 10:48 AM
Gorrella's Avatar
Gorrella
thanks i will check that out.
Old Mar 2, 2008 | 02:07 PM
hotwheels57's Avatar
hotwheels57
Since you didn't have catalytic converters with the headers, were the O2 sensors tuned out?
Would that result in the symptoms if not re-tuned for oem?
Old Mar 2, 2008 | 08:52 PM
Gorrella's Avatar
Gorrella
not sure about the 02 sensors. I did have the check engine light when i first put the lg's on but the battery died and when i replaced it the light never came back on. I have the battery disconnected now and will try the car in a couple of days to see if it helps anything. But I think the cracked plug sounds like a good posibility. I will let everyone know when I find out!
Old Mar 2, 2008 | 09:28 PM
cruisemon's Avatar
cruisemon
Check the plug wires, be sure the coil boot clicks twice, slip a nylon wire tie down along side the plug wire where it enters the boot to allow trapped air to escape.
Charlie
Old Mar 2, 2008 | 09:36 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
knock sensors can also cause this
Old Mar 6, 2008 | 07:17 PM
Gorrella's Avatar
Gorrella
It was the number three plug! Thanks for all of your help.
To HELP! car is bucking/hesitating
