Donaldson Blackwing users . . .
Old Dec 6, 2001 | 12:45 PM
Humy's Avatar
Humy
Default Donaldson Blackwing users . . .
how often you guys clean your blackwing?
Old Dec 6, 2001 | 12:50 PM
carpe dm's Avatar
carpe dm
Default Re: Donaldson Blackwing users . . . (Humy)
Humy: It depends, of course, on your driving conditions. Normal roads/driving and you can go 15-20K. Dusty/dirty roads and you may need to do it every 5 or 6K. The filter has a dodad that is supposed to tell you when it need attention, but I would probably clean it before it has that much trouble "breathing." :yesnod: :)
Old Dec 6, 2001 | 01:57 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Donaldson Blackwing users . . . (carpe dm)
Does that little filter gauge thingy work?
Old Dec 6, 2001 | 02:56 PM
4DCYKEY's Avatar
4DCYKEY
I cleaned mine after about 15K miles, when I thought it looked dirty, even though the gauge said it was still clean...
Herb
Old Dec 6, 2001 | 05:07 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
I'd be curious to hear from anyone who's Donaldson "DoDad" has popped in!! I'm leary about how accurate it is. It seems to me that it would take quite a bit of vacuum to pop the DoDad.. Perhaps a WOT run to redline would be required? :D
Also, even though everyone pig-piles on me when I say it, the Donaldson documentation states "between 50K and 100K miles in typical driving applications". Unlike changing your oil, cleaning the filter too often MAY have repercussions such as weakening the filter material.
Food for thought. I plan an cleaning mine when it looks like it needs it!
Old Dec 6, 2001 | 08:06 PM
JohnS's Avatar
JohnS
I just cleaned mine recently after about 6,000 miles. The filter was no way close to needing cleaning. I'd bet 10,000 mile would be about right. I also heard that the indicator doesn't really work.
JohnS
Old Dec 6, 2001 | 08:09 PM
vettenuts's Avatar
vettenuts
Default Re: Donaldson Blackwing users . . . (JohnS)
Does Donaldson have a web site? I would like to gather some more information on the unit and have not found it using a search engine.
Old Dec 6, 2001 | 08:26 PM
luvinc5's Avatar
luvinc5
Default Re: Donaldson Blackwing users . . . (vettenuts)
Is there anything special to the cleaner and oil for the blackwing? There was a posting by someone else saying they washed their filter with simple green and sprayed mineral oil on it when dry. Does anyone know if this would damage the filtering media on the blackwing?
Old Dec 6, 2001 | 08:38 PM
99 Corvette's Avatar
99 Corvette
Default Re: Donaldson Blackwing users . . . (luvinc5)
I don't know, but a cleaning kit only costs around $15. I wouldn't try it.
Jerry
Old Dec 6, 2001 | 08:45 PM
70L46's Avatar
70L46
CF Pit Crew
Cruise-In I Veteran
Cruise-In II Veteran
Almost CI III Veteran
Cruise-In IV Veteran
http://www.donaldson.com/
Old Dec 6, 2001 | 09:32 PM
Sixguns's Avatar
Sixguns
Many of you will no doubt clean your air filter as often as you change your oil.
however you dont have to clean it that often, infact its not good to over service an air filter. That restriction indicator is nothing new, it does work and it can be trusted and should be used as an indicator to clean the filter or not.
The Donaldson has a very large surface area and can get quite dirty and still pass way more air than the engine will ever need..
To Donaldson Blackwing users . . .
