Custom DRY KIT on it's WAY!
Dec 6, 2001 | 02:33 PM
C5Cemo, gonna have the exact same set-up as you, bud. But I have the bottle warmer and remote bottle opener! :D
100 shot on it's way! :D :D :D :D
Dec 6, 2001 | 03:08 PM
Re: Custom DRY KIT on it's WAY! (C5Noir)
Alright!! :smash:
I'm glad I could steer you into the dry direction. You won't be disappointed. Did you get the BPP WOT switch? Have you got an install date planned?
Keep us posted :cheers:
Dec 6, 2001 | 03:16 PM
Re: Custom DRY KIT on it's WAY! (C5Cemo)
No BPP switch, MTI is custom bending a microswitch to be installed at the gas pedal to deploy when it's to the floor :D. I can't wait. Going to start the install a week from Monday :D :smash:
Dec 6, 2001 | 03:46 PM
Make sure your active handling is turned off if you are only going to trigger it with the gas pedal switch - active handling engage + NOS = blown engine :seeya
Dec 6, 2001 | 03:47 PM
Re: Custom DRY KIT on it's WAY! (OliverM5)
Oliver, no AH on my ride :D. Thanks for the heads up :D
Dec 6, 2001 | 03:58 PM
Levi- I know I've already mentioned to you that I've made said mistake before...a couple times :eek: ...with no ill effect. Thank goodness!
You will need to make sure the TC is off bro. It'll do the same thing, spray nitrous without WOT.
Dec 6, 2001 | 04:11 PM
Micro switch bracket is a simple bend. You can never be to safe with your N20 system. Went with micro switch and BPP N20 electronic switch:)
Dec 6, 2001 | 04:21 PM
Sorry, I meant traction control...........
