MAF Questions
Old Dec 6, 2001 | 02:42 PM
sanchez's Avatar
sanchez
Default MAF Questions
If you got an aftermarket MAF like a Granatelli would you still need the performance MAF Housings with the air foil? Or does the Granatelli have a foil?
Thanks for any input on this rookie question.
Sam
Old Dec 6, 2001 | 04:10 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: MAF Questions (sanchez)
The GMS MAF's are complete with electronics, plastic ends, and are already descreened - that's all you will need.
-Jeremy
Old Dec 6, 2001 | 06:41 PM
sanchez's Avatar
sanchez
Thanks for the answer.
Any thoughts on which one is the best?
thanks again
Sam
Drive fast and take chances
Old Dec 6, 2001 | 07:41 PM
sanchez's Avatar
sanchez
Default Re: MAF Questions (Buckmaster)
I have a 99. I bought it used but it is new to me.
Thanks for looking out for me though.
Great looking car!!
Sam
Old Dec 6, 2001 | 08:00 PM
99 Corvette's Avatar
99 Corvette
I would suggest a set of nylon MAF ends and a MAF Translator. The way I understand it that is all a GMS MAF is the only difference would be with a set of ends and a MAFT you can adjust your air/fuel ratios and then you can tune your car just right. Is that correct? Someone please correct me if I'm wrong. :cheers:
Jerry
To MAF Questions
