Tools needed for rear rotor replacement?
Old Mar 3, 2008 | 01:38 PM
vetterlatethannever's Avatar
vetterlatethannever
Default Tools needed for rear rotor replacement?
Getting ready to do rear rotors and pads on my C5 and I was seeing what tools were necessary as my father was going to bring home what I don't have from work.
I did a search and all I found was a 21mm socket
Old Mar 3, 2008 | 01:50 PM
hotwheels57's Avatar
hotwheels57
Usually a BFH is suggested, some PB BLASTER, a large C-clamp to push the caliper pistons back into the calipers, wire brush to remove rust before re-installation...
Old Mar 3, 2008 | 05:11 PM
caleb's Avatar
caleb
5 gallon bucket turned upside down to put ur caliper on while u remove the rotor, 13/16 socket to remove caliper bolt and a cheater bar
Old Mar 3, 2008 | 05:53 PM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
Long pull bar for the 21 mm. That sob is tight.
Old Mar 3, 2008 | 06:33 PM
Mike Mercury's Avatar
Mike Mercury
Old Mar 3, 2008 | 06:52 PM
damilleniumboy's Avatar
damilleniumboy
Originally Posted by Mike Mercury
That is not a bad idea. It beats beating the thing with a rubber malet .
Old Mar 11, 2008 | 05:28 PM
vetterlatethannever
Got it done! Thanks everyone! I hit the center and rear of the rotors with some WD-40 about an hour before removal and they came right off, wonder how much it helped....
Old Mar 11, 2008 | 06:07 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
or
My method is much more fun.
Old Mar 12, 2008 | 10:29 AM
Vetterthanyou2's Avatar
Vetterthanyou2
Nice! That is usin your noggin!
Old Mar 12, 2008 | 11:35 AM
jovette's Avatar
jovette
Need torque wrench that goes up to 150 ft. lbs.
Old Mar 12, 2008 | 03:58 PM
vetterlatethannever
That sucker was on there good!!! We had the car jacked up on the rear and used another jack to provide the 'leverage' to loosen the drivers side. The passenger side we got lucky, they didn't seem as tight, maybe because the 'old man' let me do that side
Old Mar 13, 2008 | 10:00 AM
waddisme's Avatar
waddisme
Did mine last nite. I just couldn't get the car up high enough to get the leverage from breaker bar to bust bolts loose. I stopped by a tire place on the way home, they lifted up rear, broke them loose with impact wrench and then retightened them. They came loose relatively easy when I got home last nite. However, when I started last week, I PB'd one side of the car but not the other. Took about 10 min on that side. The other side took some hammering (lightly), but it came off. New drilled and slotted rotors look really nice. Not that bad of a job. Just glad to get a chance to do it before I have to do it at the track!
Old Mar 13, 2008 | 04:18 PM
vetterlatethannever
Old Mar 13, 2008 | 07:45 PM
Mike Mercury
know what ??? that probably would of went faster. I was replacing my rotors when that pic was taken.. Really didn't matter if I bent/cracked the suckers taking them off.
Old Mar 13, 2008 | 08:39 PM
Blue 92's Avatar
Blue 92
When I had my 65 GTO I called that a Pontiac wrench.
It seemed that no matter what you worked on there was always something that needed persuaded.
Old Mar 13, 2008 | 10:06 PM
vetterlatethannever
Old Mar 14, 2008 | 09:01 AM
jovette's Avatar
jovette
When I was growing up, I learned that you call that thing a Ford Wrench!
To Tools needed for rear rotor replacement?
