C5 Belts GOING BAD FAST
Old Mar 6, 2008 | 12:52 PM
YorkPaVette's Avatar
YorkPaVette
5th Gear
Default C5 Belts GOING BAD FAST
I am wondering if anyone has had this problem. The serpentine belt on my stock 1999 C5 has been replaced 5 times in the past 4 years because it develops a sqeaking that would not go away. When I look under the hood everything looks good. I just replaced the belt and belt tensioner a few months ago but now it has started again. I am not sure what the part is called but a large wheel towards the bottom of the belt has a LITTLE wobble in it. A mechanic has said that he does not think that it is the problem.
Old Mar 6, 2008 | 01:23 PM
Billysc5's Avatar
Billysc5
You will have better luck posting this in the tech forum... and Welcome to the CF.
Old Mar 6, 2008 | 01:27 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Welcome to the Corvette Forum!
Old Mar 6, 2008 | 01:46 PM
j curtiss's Avatar
j curtiss
The harmonic balancer on my '99 C5 wobbled and my belts squeaked. I replaced the harmonic balancer and the squeaking immediately disappeared.
Old Mar 6, 2008 | 01:54 PM
c5streak's Avatar
c5streak
Wobbling balancer is a fairly common problem. It will wear the belts much quicker. Do a search on here and read all about it.
Old Mar 6, 2008 | 08:35 PM
middlebrookgt's Avatar
middlebrookgt
you've got a pulley problem. Watch it run and see which wobbles. It doesn't need to be severe. If it was, the belt would be jumping over ribs
Old Mar 6, 2008 | 09:10 PM
Nver2loud's Avatar
Nver2loud
I have the same problem on my 2000....except i replaced mine twice last summer!!!!! my crank pulley wobbles a little bit, and my alternator appears it might have rubber on it, car used to charged if it matters??
Old Mar 6, 2008 | 09:14 PM
Point & Shoot's Avatar
Point & Shoot
Please switch to Goodyear Gatorback belts (sold at Auto Zone). It's like $42 for both and should permanently fix the squeal.
Old Mar 6, 2008 | 09:30 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Just met a lady with a 98C5 about 2 weeks ago at a Vette shop that was having the same problem, squeaky belt, come to find out you can see her HB wobbling, plus hers had a "nick" and the belt was coming off. Not good.
Old Mar 6, 2008 | 09:33 PM
Just say n2o's Avatar
Just say n2o
Harmonic balancer is most assuredly the problem, just went through it with mine. See if your crank bolt is loose, pretty definite sign the balancer is going bad.
Old Mar 6, 2008 | 09:43 PM
4DRUSH's Avatar
4DRUSH
Welcome to the forum
Fill out your profile information (neighbor)
BTW: you have a bad balancer
Old Mar 7, 2008 | 11:13 AM
ALVETTE00's Avatar
ALVETTE00
Funny...mine started squeeking just the other day!
I sprayed some WD40 on the belt only and it stopped, so I fgured it was just the belt and not a pulley issue? Sound reasonable?
Which pulley is the balancer, and is it a PITA to replace?
Thanks,
al
Old Mar 7, 2008 | 11:43 AM
SDPC's Avatar
0SDPC
Former Vendor
Sounds to me like it's time to upgrade to an underdrive pulley
Old Mar 7, 2008 | 11:57 AM
tallboy's Avatar
tallboy
Check out autozone and get the gator belt i had the same thing with my 99 frc and the post said go with the gator belt i had it on a year and ok with me
Old Mar 7, 2008 | 12:36 PM
timemender's Avatar
timemender
Thanks,
al
Most definitely YES a PITA
Large pulley (Harmonic Balancer) is at bottom center of the engine – end of the crankshaft.
Old Mar 7, 2008 | 12:39 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Balancer....look at the pulley you will most likely see what appears to be a rubber bushing protruding from between the pulley and the balancer....trust me on this
Old Mar 7, 2008 | 12:59 PM
j curtiss's Avatar
j curtiss
To C5 Belts GOING BAD FAST
Old Mar 7, 2008 | 01:56 PM
ALVETTE00's Avatar
ALVETTE00
Hmmm...just in case it turns out to be the worst case...
Anyone here have any "how-to's" for changing the pulley?
Old Mar 7, 2008 | 02:16 PM
Jim Taylor's Avatar
Jim Taylor
Here's the link to the ls1howto instructions for doing a head/cam swap. The balancer is part of that procedure.
http://www.ls1howto.com/index.php?article=1
Old Mar 7, 2008 | 03:28 PM
Casem1's Avatar
Casem1
I have avatar envy...
