C5 Belts GOING BAD FAST
Old Mar 7, 2008 | 05:04 PM
YorkPaVette's Avatar
YorkPaVette
5th Gear
Default Bad Belts
Originally Posted by Jim Taylor
Here's the link to the ls1howto instructions for doing a head/cam swap. The balancer is part of that procedure.
http://www.ls1howto.com/index.php?article=1
Thanks for the link.
Old Mar 7, 2008 | 05:06 PM
j curtiss's Avatar
j curtiss
Originally Posted by Casem1
I have avatar envy...
Me too!
Old Mar 7, 2008 | 05:10 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Originally Posted by timemender
Most definitely YES a PITA
Large pulley (Harmonic Balancer) is at bottom center of the engine – end of the crankshaft.
a PITA....
On a side note, I believe a certain Avatar here, needs to be "patted" down.....
Old Mar 8, 2008 | 09:27 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
Originally Posted by j curtiss
Me too!
Add me to the list as well. I forgot what the topic was about.
As stated, it's a good time to do a pulley upgrade. If you are planning on having a cam install, now is the time to do so because the pulley install will be part of it, thus free labor.
Old Mar 10, 2008 | 10:43 AM
ALVETTE00's Avatar
ALVETTE00
I checked the pulleys this weekend...and they didn't have any wobble. Looked brand new.
If fact...there was no squeek either
I really hope it's just the stupid belt.
al
Old Mar 10, 2008 | 06:10 PM
Jim Taylor's Avatar
Jim Taylor
Ha! I'll let her know you appreciate her. We've been married 26 years, and she's had four boys. I'm a lucky guy!
Old Mar 11, 2008 | 07:50 PM
TheeMike's Avatar
TheeMike
You are a lucky man.
As for the issue at hand, mind has a slight squeak most of the time, but when it gets wet it is horrible.
I hate to have to change the HB and may just try the belt first. HB looks like a huge chore that will eat an entire Saturday (maybe event he entire weekend).
If i go with an undersized pulley do i need to get a different belt as well?
Old Mar 12, 2008 | 09:56 AM
Jim Taylor's Avatar
Jim Taylor
Mike, you need a different main belt with an underdrive pulley, but the A/C belt shouldn't change. The pulley is a major job, but people have reported major disasters with the OEM pulley coming apart. If you decide to do it, put a pin in the crank to keep the pulley from backing off the crank. You'll find lots of posts about this if you do a search.
Old Mar 12, 2008 | 12:26 PM
TheeMike's Avatar
TheeMike
Thanks for the suggestion. I think i may do that later this spring and may as well put in a slight cam while i have things torn up.
