Head Selection - Question
Old Mar 6, 2008 | 08:31 PM
crosstheline's Avatar
crosstheline
Default Head Selection - Question
I recently had the following mod's completed on my 04/A4:
Comp Cam 233/239 .588/.595 113 lsa
Underpulley
160 degree thermostat
Dynatech Supermaxx headers w/x-pipe
Corsa Touring
Vararam
3600 Yank Converter - Cooler
3:73 Differential
Tune
By the way, based off of my previous questions concerning the above, the forum member here "steered me" in my selection of these modifications.
Question I now have; I would like to put a set of heads on to compliment the cam and the rest of the mod's. What is your thoughts on head selection along with throttle body? Is the Fast 90 worth the addtional h.p. as well?
By the way, I made 385 rwhp and ~365 rwtp on a Mustang Dyno with the mod's so far. I believe on a DynaJet I would be around 400-410 rwhp. With the heads/T.B. what additional h.p. do you believe this will make?
If you would, please explain why you prefer a certain head.
Old Mar 6, 2008 | 08:58 PM
Brad@RevXtremeAutoSports's Avatar
If you have the money go AFR (their reputation speaks for itself) and yes a ported FAST 90/90 will add to your combo.
Old Mar 7, 2008 | 08:18 PM
crosstheline
bttt
Need some opinions!
Old Mar 7, 2008 | 08:26 PM
vettenuts's Avatar
vettenuts
I am installing my AFR's in a few weeks. Guess you know what my recommendation is.
Old Mar 7, 2008 | 08:56 PM
slvr76's Avatar
slvr76
I just ordered a set of TFS 215cc heads, so I guess thats what I'm voting for.
Old Mar 7, 2008 | 09:48 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
You can't go wrong with either AFR or TFS heads! But both are pricey. Patriot makes a decent head. And the new LS3 heads are phenomenal for stockers.
Old Mar 7, 2008 | 10:42 PM
pit-man's Avatar
pit-man
Originally Posted by crosstheline
bttt
Need some opinions!
AFR
Old Mar 7, 2008 | 11:18 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Do it right the first time!
Old Mar 8, 2008 | 12:48 AM
One Nut's Avatar
One Nut
AFR's 205's w/62cc chambers ported with fast 90/90 with 30 lb injecters. or I've herd of a 100mm intake i think from weiand in that case use a billit tb 100mm with 30 lb injecters. I dont know about that cam but the stock injecters may not support all that go fast stuff. Your set up sounds just like what I have planed for mine all i need now is the heads cam & intake...
Old Mar 8, 2008 | 01:11 AM
BlueRag's Avatar
BlueRag
I'm joining the "AFR 205" club too..........I just talked with Tony at AFR and I'll have a set in two weeks
Old Mar 8, 2008 | 07:50 AM
vettenuts's Avatar
vettenuts
You will probably gets yours installed before mine. I have go to move to somewhere warm
Old Mar 8, 2008 | 10:06 AM
LDB C5's Avatar
LDB C5
Trick Flow here
Old Mar 8, 2008 | 07:09 PM
DALE C's Avatar
DALE C
I love the ETP's if you are willing to spend the money, we put a set of 225's on the motor we built for my wife's FRC 346ci 10.75 compression fast 90-90 with a cam not much more aggressive than yours and made 490 RWHP
Old Mar 8, 2008 | 07:57 PM
spiral04's Avatar
spiral04
Another vote for the TFS 215's Check my signature.
To Head Selection - Question
