A couple electrical issues
Old Mar 6, 2008 | 09:12 PM
grady's Avatar
grady
Default A couple electrical issues
After a long winter's nap, two issues. The radio will not turn on and I get a no communication for the RADIO on the DIC. Hope this is a fuse issue.
The second is the driver side headlight motor continue to attempt to lower the headlight after it is completely lowered. It runs a few seconds after fully lowered and makes a buzzing sound like two gears running against each other.
I'd appreciate some help. Thanks
Old Mar 6, 2008 | 09:30 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
First thought is the battery is still low. I would suggest charging it first, then restart and see if the problems are resolved.
Old Mar 7, 2008 | 10:46 PM
HPS MASTER TECH's Avatar
HPS MASTER TECH
you need a new head light motor. the grinding you hear is the gears inside slipping
Old Mar 8, 2008 | 10:01 AM
tommybilt's Avatar
tommybilt
Just a thought on the radio. Door modules can screw that up. Do you have lock and window function?
To A couple electrical issues
