Which piston is number 7?
Mar 6, 2008 | 10:49 PM
I tried a search and nothing really came up but is #7 on the back drivers or pass side?
I am going to do a compression test on it to be SURE I dont have a problem cause I am going nuts now due to the fact I have heard of ppl not knowing they are driving on a low pressure cyl
Mar 6, 2008 | 10:52 PM
It should be on back of the engine on the drivers side if I remember correctly. It is the toughest of the spark plugs to get out.
Mar 6, 2008 | 10:53 PM
I believe it is on the drivers side closest to the firewall.
Mar 6, 2008 | 11:26 PM
Mar 7, 2008 | 01:25 AM
From radiator to firewall, on driver's side: 1,3,5,7
From radiator to firewall, on passen side: 2,4,6,8
Mar 7, 2008 | 04:18 AM
That's it - 1,3,5,7 on left facing forward. 2,4,6,8 on right!!
Mar 7, 2008 | 09:59 AM
Toss up on hardest sparkplug to remove, #1 is no picnic either.
Mar 7, 2008 | 11:31 AM
Thanks guys, I went ahead and did a compression test on #5 and #7 as I have heard these are the first to go, well there at 160 each (cold motor, 6 revolutions) so looks like I am good!!!!
Mar 7, 2008 | 12:33 PM
Quote:
Originally Posted by
Corvette Don
In the future, a vacuum gauge is much easier and faster. It will tell you in seconds whether you have a problem.
Mar 7, 2008 | 02:26 PM
FRCTony
Where would I hook the gauge up too? Each cyl?
Mar 7, 2008 | 03:14 PM
Corvette Don
Probably need to get a tee and plumb it into the brake booster line.
You are just reading manifold vacuum, not anything cylinder specific.
Mar 7, 2008 | 11:54 PM
FRCTony
what should the vaccum gage read ??????????? whats good vs whats bad ?
Mar 8, 2008 | 10:32 AM
rustyguns
On a stock engine, 18-20" and steady at warm idle.
If you have a cam, you'll have to take note after the install.
The main thing is that it is steady and consistent. It might vary a little depending on weather or altitude, but it must remain steady.
Here is a decent link:
http://www.international-auto.com/in...m?fa=ad&aid=47
Mar 8, 2008 | 10:36 AM
another way to identify #7 is to change your spark plugs.
The one that is an absolute nightmare to remove; that one that will cause you to invent new cuss words... is #7.
Mar 8, 2008 | 12:13 PM
Cruise-In VII Veteran
only a Ford would have them in sequential order on each bank
Mar 8, 2008 | 12:14 PM
Left bank is Passenger side
Right bank is Drivers side
8 7
6 5
4 3
2 1
