Re-use Caliper Bracket Bolts
Old Mar 7, 2008 | 10:08 PM
Safedog's Avatar
Safedog
Default Re-use Caliper Bracket Bolts?
I purchased a 1/2" impact wrench to remove these....can I re-use them with re-applying red loctite?
I was worried about "hurting" them when I removed the from the 125 ft. pounds of torque + red loctite.
Thanks folks in advance.
Karl
Old Mar 7, 2008 | 10:32 PM
Gideon's_Test's Avatar
Gideon's_Test
It is recommended that if you re-use them (which many have done) that you use a die or something to chase the old loctite off of the threads and yes, fresh loctite is highly recommended.
thetaxman's Avatar
thetaxman
GM says no because of legal liability
I personally have reused them numerous times
Old Mar 7, 2008 | 10:33 PM
Gideon's_Test
By the way, I have used a blow torch to heat the bracket a bit to soften the old loctite, and used an impact wrench to loosen them. Had no problems.
Old Mar 7, 2008 | 10:34 PM
thetaxman's Avatar
thetaxman
Old Mar 7, 2008 | 10:36 PM
Gideon's_Test
Ok, I meant a propane torch...I can see why you were bothered by that...
Old Mar 7, 2008 | 11:34 PM
rustyguns's Avatar
rustyguns
yeah but blow torches are kewel!
I re-use mine and don't use loctite ! 125 lbs will hold anything!
put 6 sets of pads on so far nothings fell off !
Old Mar 8, 2008 | 12:29 AM
waddisme's Avatar
waddisme
Same here. I have to remove before and after track days so Locktite seems overkill. 125 lbs is definitely a lot
I actually use the same guide pin bolts. Cleaned the loctite off with tap screw. I just check them when I torque wheels between sessions to make sure they are not coming out. Seems like that was the consensus from the track guys.
Old Mar 8, 2008 | 02:38 AM
thetaxman's Avatar
thetaxman
I reuse the caliper bolts and the caliper mount bolts
NEVER had any issues of any kind and I never bother with loctite
Old Mar 8, 2008 | 07:41 AM
rws.1's Avatar
rws.1
I reuse mine changing rotors and pads at least 10X per season..I change from bling to auto-x and back for each event.
In the beginning I just used a utility knife and wire brush...
But then I read a forum post and now I use two dies
M14x2.0 for the bracket bolt
M8x1.25 for the caliper bolt
cleaner threads, less time
Old Mar 8, 2008 | 09:04 AM
j curtiss's Avatar
j curtiss
Wow, that's interesting. All this time I thought the caliper bolts were torque-to-yield bolts, which should not be reused.
Old Mar 8, 2008 | 09:27 AM
bumble-z's Avatar
bumble-z
The bracket bolts require gorrilla torque(125?) The caliper bolts only re quire about 35/45? ft. lbs. It wouldn't take long to stress the caliper bolts , if you wasn't carefull and not over torqueing. Bob.
Old Mar 8, 2008 | 09:38 AM
white top's Avatar
white top
GM dealer had to remove mine used the same old bolts. I bet there are few dealers who bother to use new bolts.
Old Mar 8, 2008 | 09:46 AM
lar66BB's Avatar
lar66BB
Default bolts
Old Mar 8, 2008 | 09:58 AM
Secret237's Avatar
Secret237
I reuse mine as well, a 14mm bolt can handle a torque of 125 as long as it's a higher grade bolt , like a 10.9 (grade 8) and I'm sure it is.
Bolts will stretch after a while of torquing and untorquing and these types of bolts, because they are important, should be replaced after a while, maybe 50 reuses or so. Headbolts do the same thing, after a while they will break.
But yes, use the Loctite Red (#272) unless you think you need the higher temp stuff (#274).
Why not ?? It can't hurt to make sure these bolts don't fall off.
To Re-use Caliper Bracket Bolts
