Autumn Reminder
Old Dec 7, 2001 | 09:45 AM
Black2001Z06's Avatar
Black2001Z06
Default Autumn Reminder
I know this was posted several weeks ago, so sorry for the re-post, but I think it's worth bringing to everyone's attention again. CHECK YOUR RADIATOR. Last couple of times we've take the Z out, we've noticed a funny smell, plus the temps have been running a few (5-10) degrees higher. Sure enough, all kinds of leaves, bugs, lizzards (I guess these are what smelled). Also, if you live in a cooler climate, you'll probably need to air up the tires a bit. I was about 3.5-5 pounds low all around. Interesting thing too..when I dress my tires, I go into the first tread block so that when the tire rolls, it cleans off that dressing, but is dressed all the way to the edge. When down 3-5 pounds, the dressing wasn't getting cleaned off, so it's easy to see that a slight air pressure adjustment will probably make a big difference in long term wear.
