fuel & ignition problems?
Old Mar 8, 2008 | 09:39 AM
ikester12's Avatar
ikester12
Cruising
Default fuel & ignition problems?
hey everyone,
ok so i just installed NGK iridium IX plugs and MSD wires, the computer had a blast trying to reset, but my question is after i did the install the RPMs at idle are very sporadic and drop to about 400 and back up again, has anyone else had a problem when they did similar upgrade? also on a side note is there a block on the fuel line when disconnected? since there is no return line i thought when i took off the braided fuel line from the rails it would shoot fuel everywere, not a drop!
Any help would be appreciated
Old Mar 8, 2008 | 10:12 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The first thing I would check is to make sure all of the plug wires are tight, if they are then ditch the MSD wires and go back to factory.
I personally had a problem with MSD wires on my 03 Coupe and I know I have read on this forum several other members who had problems after installing these.
As far as the fuel issue goes, if your car has sat overnight before disconnecting the fuel line, you may not get any fuel out of the line when disconnecting it.
Old Mar 8, 2008 | 10:21 AM
ikester12's Avatar
ikester12
Cruising
it was sitting for maybe an hour. also the stock wires came appart out of the boot so they were needing a replace anyway,
Old Mar 8, 2008 | 11:00 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
It sounds like a wire issue. Sure they are on all the way?
Old Mar 8, 2008 | 11:27 AM
ikester12's Avatar
ikester12
Cruising
the spark plug and wire right behind the brake booster gave me the most trouble, and i didnt seat the boot all the way the first time and misfired, but i cleared the code took off the coil railing and i was able to push it all the way in, i checked the rest of the plugs and wires and they are all in properly. the idol is rough at start up but when i give it some gas it is really smooth so i think i might have to do with my fuel pump?
Old Mar 8, 2008 | 06:02 PM
dgrant3830's Avatar
dgrant3830
Ok, so now comes the question, was it idling this way before you changed the plugs? Correct plug? Correct plug gap?
Old Mar 8, 2008 | 10:58 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
If it is a NEW problem after the wires/plug install--chances are that a plug gap got accidently closed when installing it--OR a wire is NOT on all the way--You need to hear a double clik on the coil end--Also--the MSD wires are known to have issues with the boot popping off or not snapping on correctly
If you dis connected the battery to do the install-- the fuel trims were probably re-set and will have to re-learn the idle all over again--the more mods you have the longer it takes--can take up to 100 miles sometimes-------If you have a scanner -check you LTFT's at idle--
Old Mar 8, 2008 | 11:24 PM
lucky131969's Avatar
lucky131969
Originally Posted by ikester12
hey everyone,
Ok, I'll ask.....why did you disconnect the fuel rail to change plugs and wires?
Old Mar 10, 2008 | 06:06 PM
ikester12's Avatar
ikester12
Cruising
i painted the rails, but the issue was before the rails
To fuel & ignition problems?
