Have a weird problem...
Old Mar 8, 2008 | 06:22 PM
Blown-Interceptor's Avatar
Blown-Interceptor
Default Have a weird problem...
Went out today and sprayed a 100 wet shot, after I let off, the clutch was stuck to the floor and I lost my brakes. The brake pedal would not even go down an inch, it was like pressing a concrete wall.
I have the nitrous for about three years, and it just started doing this.
Any ideas?
Thanks,
Jason
__________________
1998 C5 Silver Corvette
Borla Cat-Back, LT's, B&M Ripper,VaraRam, Air Coupler, LS6 Intake, NX Wet kit, TR 224/224, Ported TB, High Flow Air Bridge
Old Mar 8, 2008 | 07:17 PM
lucky131969's Avatar
lucky131969
Any ideas?
Thanks,
Jason
__________________
Have you checked the vacuum to brake booster.
Old Mar 8, 2008 | 08:23 PM
noahdr's Avatar
noahdr
brake booster and check valve. clutch fluid probably burnt up too.
Old Mar 8, 2008 | 08:25 PM
Blown-Interceptor
Yup, everything looked ok.
Old Mar 8, 2008 | 08:26 PM
Blown-Interceptor
The clutch fluid was pretty dirty, I just got some paper towels and soaked up the fluid and put new fluid in.
Old Mar 8, 2008 | 11:19 PM
lucky131969
What do you mean "looked ok", did you test the vacuum with a gauge?
Old Mar 8, 2008 | 11:35 PM
Blown-Interceptor
No, I looked to see if it was cracked. I guess I should just replace it, it's the piece that's on the brake booster that connects the hose that goes to the back of the intake, right?
Old Mar 9, 2008 | 12:09 PM
noahdr's Avatar
noahdr
Thats the brake booster check valve. Its just basically a one way valve. Its easy to test. Take it off and try to blow through it. It should only allow air to move one way. If you have good vacuum pressure from the intake and that valve is ok, then you need a new brake booster.
Old Mar 9, 2008 | 12:17 PM
Blown-Interceptor
I just took it off and tested it. It will only allow air to flow in one direction, so I guess the check valve is ok. I guess I am looking to get a new brake booster, are those hard to install?
Old Mar 9, 2008 | 12:35 PM
lucky131969
I suggest you break out your service manual and troubleshoot instead of just replacing parts. You really need to verify that the brake booster is bad, and not the vacuum source. The manual will take you through the check step by step.
Old Mar 9, 2008 | 12:39 PM
Blown-Interceptor
I really need to get one...any suggestions which one?
Old Mar 9, 2008 | 06:04 PM
lucky131969
GM.
To Have a weird problem...
