C1247 is associated with the braking system. Is it H or C and do you have the red brakes warning caption?
Checking the manual, the brake fluid level switch monitors the fluid level. If it senses a low level it brings on the red warning flag on the IPC and sets the DTC.
Probably as simple as a quick fluid top up. Remember to use the correct DOT spec (DOT3 if you're stock)
