Code po492hc
Old Mar 9, 2008 | 06:22 PM
RAY 1's Avatar
RAY 1
Default Code po492hc
I can't find this code on list. What is it? I just started getting a check engine light that goes out on its own after 3 or 4 starts then it comes back on. Dealer wants me to bring it in and won't tell me what code means. Thanks.
Old Mar 9, 2008 | 06:45 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
From the 2004 service manual:
The PCM detects a system air flow condition by monitoring the heated oxygen sensors (HO2S) and Short Term Fuel Trim during normal Open Loop AIR system operation. This is a passive test. If the passive test indicates a pass, the PCM takes no further action. If the passive test fails or is inconclusive, the diagnostic will proceed with an intrusive or active test. The PCM will command the AIR system ON during Closed Loop operation under normal operating conditions. The active test will pass or fail based on the response from the HO2S. A lean HO2S response indicates that the AIR system is functioning normally. An increasing Short Term Fuel Trim value also indicates a normal functioning system. The AIR diagnostic consists of the passive test and the active tests. The AIR diagnostic requires failure of the passive and active tests on 2 consecutive key cycles to illuminate the malfunction indicator lamp (MIL) and stores a DTC. If the PCM detects that the HO2S and Short Term Fuel Trim did not respond as expected on one of the engine banks, DTC P0491 for bank 1 or DTC P0492 for bank 2 sets.
MIL = check engine light; Bank 1 = driver side; bank 2 = passenger side
HTH!
Old Mar 9, 2008 | 07:20 PM
RAY 1's Avatar
RAY 1
So where do I start. How do I fix it?
Old Mar 9, 2008 | 10:47 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
There are several possibilities.
  • excessive exhaust back-pressure
  • upstream air leak between the AIR pump and where it eventually plumbs into the exhaust manifold
  • bad O2 sensor
Excessive back-pressure could be caused by a failed/clogged catalytic converter or a partially crushed pipe (like if you bottomed badly). If you still have stock exhaust, check for equal exhaust flow coming out of the left and right tailpipes. The factory H-pipe will somewhat skew the results, but since the opening in the "H" is small, you should still be able to tell if there is a difference. If one side is flowing less and you don't see evidence of any crushed section of pipe, suspect the cat (or pre-cat, if you have them) on that side.
Air is injected into the exhaust port via the fitting on the exhaust manifold, upstream through a check valve, and eventually back to the AIR pump. It's not unusual for the check valves to sieze or rust shut, especially on cars that see a lot of short distance driving, where the engine doesn't get a chance to fully come up to temp and burn out condensation. Check the easy stuff first. Trace the plumbing back and look for evidence of any kinked hoses, loose connections, missing clamps or audible leaks. The AIR pump normally only runs for a short period of time at cold engine start-up, so that would be the time to check for leaks. A piece of hose can be used as a stethescope to help you pinpoint location. If you don't find anything conclusive, your check valve may be frozen in positon. If you feel lucky, you can try spraying some anti-seize or WD-40 in the hose toward the valve. Really soak it, and then let it sit overnight. Clear the codes, then restart the car and see if it comes back. Remember that it takes two consecutive ignition cycles with a failure before the CEL comes on.
If you still have a problem at this point, it's probably best to have a professional look at it. It can become expensive if you just guess and start shotgunning parts.
GL!
Old Mar 10, 2008 | 11:07 AM
c5streak's Avatar
c5streak
  • bad O2 sensor
GL!
Had that code on my '04. It was a check valve. I have GMPP and my dealer just replaced both check valve for me.I would try cleaning them first.
Old Mar 10, 2008 | 10:36 PM
RAY 1's Avatar
RAY 1
Is this something I can do? Or do you recommend dealer on changing it. I'm not going to fool with cleaning it. My wife drives sometimes and she freaks out about every little thing!
Old Mar 11, 2008 | 05:30 PM
c5streak's Avatar
c5streak
GL!
Sorry, don't have any pics to show the check valves, but there is one on each side. Pull the hose off and try to soak them. It' worth a try.
To Code po492hc
