Multi-CD player problem
Old Mar 9, 2008 | 06:56 PM
pennstater86's Avatar
pennstater86
5th Gear
Default Multi-CD player problem
I have a 97 Vette and recently my multidisc CD player got jammed (I think there is a disc stuck in it) - turns on, but won't eject/play/etc. Any suggestions?? Many thanks
Old Mar 9, 2008 | 10:16 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Slide a puddy knife between the cartridge and the changers housing, it allows for manual release.
Old Mar 9, 2008 | 10:24 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Or you can take it out and then take it apart. Usually the safe way.
Old Mar 11, 2008 | 06:00 PM
bighank's Avatar
bighank
Default Where do you do this
I just removed a 12 CD Pioneer changer and it has the cartridge with the 12 CDs inside. Where do you slide the putty knife. Can you restore the cartridge after removing the CDs without power.
Do you know the pinouts for the wires coming out of the plug. Need to put this in another vehicle. BIGHANK
To Multi-CD player problem
