Low oil sensor?
Old Mar 10, 2008 | 10:11 PM
PushinTheLimit's Avatar
PushinTheLimit
Default Low oil sensor?
Ok, I am still a newb with the vette... I just bought mine this weekend. Its an 02 C5 Z06. When I was about to leave with it, I noticed the HUD displayed "low oil level". The display was showing I think 4 bars, as it looks like 7-8 bars would be at the top. So I put a qt in it and it only went to 5 bars, but the low oil message never popped up again for the 400 mile trip home.
Sunday, we changed the oil... put almost 7 qt. in it of Mobil 1 fully synthetic 5W30. After the change, it was still only reading 5 bars on the oil level in the HUD.
I took it out today and while I was driving, the "low oil level" popped up again. I checked my garage floor and I don't see any leaks. I check the dip stick and it looks like its right above the "ADD" and in the ok section. But it still only displays 4-5 bars in the HUD on the oil level indicator.
So I'm not sure whats up. I'm wondering if its a bad sensor or have a got other problems. The car seems to run fine and I don't hear anything out of the normal. Is it typical that the oil level indicator in the HUD never goes past 5-6 bars?
Old Mar 10, 2008 | 10:59 PM
waterzap's Avatar
waterzap
Is there an oil level indicator? I thought it was oil pressure on the HUD?
Old Mar 10, 2008 | 11:08 PM
PushinTheLimit
Ok maybe it is the oil pressure indicator on the HUD and not the oil level indicator.
I checked the dip stick again, and it did look a lil low. I added almost a qt. and that put it to the max line so looks like its good to go now. I guess it's holding more oil that I thought it would. There's no smell indicating burning alot of oil and there's no leaks either.
Old Mar 10, 2008 | 11:20 PM
waterzap's Avatar
waterzap
Dont put in too much oil. Thats a sure way to damage the engine. A little over is ok, but too much will kill the engine just like too little. The oil pressure varies by things like the temperature of the engine and how hard you are driving. Mine goes up and down, 3 bars, 4 bars, 5 bars, back to 4 bars. All good.
Just as a side note, I always have trouble reading the dipstick. Whole thing has a thin film of oil on it when I pull it out, and the oil is so clear (just changed it), that it is a bit tough getting a reading. I think mine took 6.5 qts in total, including the oil in the filter. 7 is probably pushing it. With 8, I would definitely start wondering what is going on.
Old Mar 11, 2008 | 08:26 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
By any chance do you park your car level or is it on an incline?
Old Mar 11, 2008 | 09:48 AM
4SFED Z's Avatar
4SFED Z
Do you have LT headers? I do and my car tend to get the low level light if I drive it hard because its burns more oil. When the light comes on, add a quart and your good to go. I too have no leaks.
Old Mar 11, 2008 | 10:19 AM
PushinTheLimit
Just stock headers. I added 1 qt. to it last night and it filled it to the top line where it should be. Drove it to work this morning and checked it, looked good and the oil pressure seemed to be just fine while driving too.
Maybe we didn't add as much oil in it when we changed as we thought we had. Anyways, all's well. Thanks for the help guys.
Old Mar 11, 2008 | 10:26 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
7 quarts with a new filter will get you to the full line on your dipstick. The car has capacity to hold at least 2 more quarts. When running HPDEs I overfill the sump by a quart and let it be... eventually the car will burn the extra off over time. My car uses maybe a quart between 6000-7000 mile oil changes after the GM re-ring in '04.
The low oil leve indicator will come one when you get 2 quarts low I believe... I can't remember... I had it happen back in '03 before I had the re-ring done and my car was a heavy oil burner.
Old Mar 11, 2008 | 02:42 PM
jovette's Avatar
jovette
Believe you are correct. Only oil pressure reading is available on my '00 HUD. And four / five bars sounds about what I typically see, if I recall correctly.
To Low oil sensor?
