Do I need window alignment?
Old Mar 10, 2008 | 10:13 PM
miltievette's Avatar
miltievette
Default Do I need window alignment?
Ok can someone tell me what I should do? Driver and pass door windows don’t line up right at the upper rear corners where it meets the roof. When I get out I have to be careful and remember to put my index finger on the Glass and push the door close. The glass will snug right under the top the same goes for the pass. Side. When I get in to drive I lower the window and raise it after I buckle up. I want to fix it is this an ez repair or should I take it someone. PS. I drive a 2000 Vert. If I forget to lower the glass and raise it I get wind noise. I never notice this when my top is down. Thanks for the HELP
