Headlights Up
Old Mar 12, 2008 | 11:58 AM
NSTY C5's Avatar
NSTY C5
Default Headlights Up
Is there a way to have headlights up and all lights off? I can get headlights up and off but running lights stay on. Thanks
Old Mar 12, 2008 | 12:01 PM
corvettebob1's Avatar
corvettebob1
Open the hood and turn the **** on the motors until they are up.
Old Mar 12, 2008 | 12:03 PM
yellohvette's Avatar
yellohvette
Turn the headlights on, once they are up, disconnect the wire harness (2 of them).
Do you want this to be permanent (ie - always have the headlights up, but still retain full functionality?) If so, do the above step and then snip the ground wire that goes to the motor. You can then crimp on some adpaters so that you can easily reconnect when needed. Reconnect your wire harness (2 of them)
Dunno if there is any other way to do what you want.
To Headlights Up
