Help: door panel removal help needed
Old Mar 13, 2008 | 07:58 AM
litpy's Avatar
litpy
Default Help: door panel removal help needed
Does anyone have detailed pics of how to remove drivers side door panel? Everytime I try to pry off it sounds like it it cracking, I am using the same fork to get them off as I did with the hood blanket.
Old Mar 13, 2008 | 08:56 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
I don't have pics or know all the details, but I have watched my brother remove door panels many times. There are several screws that hold the panel in place near the door latch if I recall. In addition, there are a number of plastic pins holding the door in place. You also need to pull out the electronic control module before you remove panel so you don't tear any wires.
My brother is on here frequently and you can pm him if you like. He goes by AJG1915.
Hope that is of some help.
Lowcash's Avatar
Lowcash
Give this a try.
http://www.vetteessentials.com/instr...or_handle.html
Old Mar 13, 2008 | 09:51 AM
litpy's Avatar
litpy
Like usual Great help. Can't wait to get off work to try and repair speaker. Had car in for mirror work and now speaker does not work. Hopefully just bad connection. Again thank you for all your help.
Old Mar 13, 2008 | 10:10 AM
Lowcash's Avatar
Lowcash
No problem!
Old Mar 13, 2008 | 11:13 AM
timemender's Avatar
timemender
Sounds like the mirror repair person/shop is responsible. Point it out to them. Especially if it was working before they tore into it.
Old Mar 14, 2008 | 08:18 AM
litpy's Avatar
litpy
Again thanks for all your help, took about 10 mins. to get panel off. And just as I thought speaker was unplugged, plugged it back in and all is fine!
To Help: door panel removal help needed
