Help with codes!!!!
Old Mar 13, 2008 | 10:01 AM
Venomized03's Avatar
Venomized03
Default Help with codes!!!!
Well I just installed a magic stick 4 cam in the car this week. Started it up for the first time last night and 2 codes keep comming up and the check engine light is flashing. Is there a place where I can look up the codes or can someone tell me what they are on from.
1. PCM code --- PO300 C
2. HVAC code --- U1160 H C
The car was running EXTREMELY rich. My eyes were burning baddd within 30 sec of running. Im sure its due to the engine code but let me know if this is normal.
Also, oil pressure is definitly lower than it used to be. At idle its between 25-30 PSI. It is only idleing at 700 rpms now though. I held the RPM's up at 2500 for maybe 10 sec and it went to 38 PSI. That seems really low, b/c on cold start ups it used to be at 60 PSI. I know the O-ring is not pinched on the oil pump. Is there anything else that it could be?
Old Mar 13, 2008 | 11:07 AM
87SAM's Avatar
87SAM
DTC U1160 Loss of Communications with LDCM. That's all the info I can find on this one.
DTC P0300
System Description
The powertrain control module (PCM) uses information from the crankshaft position (CKP) sensors and from the camshaft position (CMP) sensor in order to determine if engine misfire is occurring. By monitoring the variations in the crankshaft rotational speed for each cylinder, the PCM is able to detect individual cylinder misfire events. A misfire rate that is high enough can cause damage to the three-way catalytic converter (TWC). The malfunction indicator lamp (MIL) will flash if converter damage conditions are present.
Conditions for Running the DTC
• DTCs P0101, P0102, P0103, P0117, P0118, P0125, P0335, P0336, P0341, P0342, P0343, P0500, P0502, P0503, P1120, P1220, P1221, or P1258 are not set.
• The engine speed is between 425-3000 RPM.
• The ignition voltage is between 10-18 volts.
• The engine coolant temperature (ECT) is between -7°C-130°C (+19°F-266°F).
• The fuel level is more than 10 percent.
• The throttle angle is steady within 1 percent.
• The anti-lock break system (ABS) and the traction control are not active.
• The transmission is not changing gears.
• The secondary air injection (AIR) diagnostic test is not in progress.
• The A/C clutch is in a steady state.
• The engine is not in fuel shut-off or in decel fuel cut-off.
• The antilock brake system (ABS) signals are not exceeding the rough road thresholds.
Conditions for Setting the DTC
• The PCM determines that an emission type misfire is present.
• The PCM determines that a catalyst-damaging misfire is present.
Action Taken When the DTC Sets
• The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
• The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
• The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
• A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
• A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
• Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
Important
• Before you service the PCM and the throttle actuator control (TAC), remove any debris from the module connector surfaces. Inspect the module connector gaskets when you diagnose or replace the modules. Ensure that the gaskets are correctly installed. The gaskets prevent contaminate intrusion into the modules.
• For any test that requires probing the PCM or probing a component harness connector, use the J 35616-A connector test adapter kit . Using this kit prevents damage to the harness and component terminals. Refer to Using Connector Test Adapters in Wiring Systems.
• Running the vehicle out of fuel causes sufficient misfire to set DTC P0300. A vehicle that is out of fuel may have DTC P0461 and DTC P1431 also set.
• A restricted fuel filter can cause sufficient misfire to set DTC P0300. Refer to Fuel System Diagnosis .
• A misfire that only occurs during certain conditions may be difficult to locate. Observe the Freeze Frame and the Failure Records in order to determine when the DTC set.
• Excessive vibration from sources other than the engine could cause a misfire DTC. Possible sources of vibration are listed below:
o Variable thickness in the brake rotor
o An unbalanced propeller shaft
o Certain rough road conditions
• If more than 1 cylinder is misfiring, the scan tool may only display 1 misfiring cylinder. This condition is not apparent until the repair is completed. Also, if an ignition coil or module ground circuit is open for 1 side of the engine, the scan tool may only display 2 or 3 misfiring cylinders. Inspect the ground circuit for the ignition coil and for the modules on the cylinder bank of the engine that has more than one misfiring cylinder.
• A misfire may not be apparent at idle. The misfire may only occur above idle during a load. Road-test the vehicle, and monitor the misfire current counters.
• For an intermittent condition, refer to Intermittent Conditions .
Old Mar 13, 2008 | 07:22 PM
Venomized03
Wow thanks man. I think the PO300 code is from the huge cam thats in it. I am mostly worried about the HVAC one now and why the oil pressure has dropped so much
ANYONE???
Old Mar 15, 2008 | 08:34 PM
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
Did you pull the oil pump off? If so, its very easy to tear/pinch/lose the o-ring that attaches the pump to the pickup and it will cause low pressure.
To Help with codes!!!!
