Gear swap
Old Mar 13, 2008 | 01:00 PM
C5UL8R's Avatar
C5UL8R
Default Gear swap
i am doing a 3.42 gear swap into my 01 a4 2.73 and i read that you have to break the new gears in, for how long? How many miles?
Old Mar 13, 2008 | 01:13 PM
jirasvet's Avatar
jirasvet
I beleive the rule of thumb is 500 miles, not to exceed certain rpms an MPH
Old Mar 13, 2008 | 01:28 PM
C5UL8R's Avatar
C5UL8R
thanks do you know the rpm, mph
Old Mar 13, 2008 | 01:56 PM
jirasvet's Avatar
jirasvet
generally i think it is around sixty and no hard accelerations over 3000 rpm
Old Mar 13, 2008 | 02:18 PM
C5UL8R's Avatar
C5UL8R
thanks alot
Old Mar 13, 2008 | 02:22 PM
C5UL8R's Avatar
C5UL8R
its gonna be hard to lay off i am also getting a new stall converter
Old Mar 14, 2008 | 10:37 PM
jaygood's Avatar
jaygood
What are your times on the track?
Old Mar 14, 2008 | 11:38 PM
Bluefire's Avatar
Bluefire
I bought one from DTE (great gears!). The documents that came with it just said no WOT until 500 miles have past. During that time I didn't take it much past 3K rpm's either. You also have to change the gear oil after the break-in period.
Old Mar 14, 2008 | 11:45 PM
black98c5's Avatar
black98c5
I drove my car for 500 miles with no WOT runs or hard launches...it took a lot of self control to say the least but it was well worth it.
Old Mar 15, 2008 | 10:28 AM
Bluefire's Avatar
Bluefire
Man, I agree. It takes all the self control in the world.
Old Mar 15, 2008 | 11:18 AM
fuel_junkie's Avatar
fuel_junkie
I must have been mis-informed. I thought you had to replace the whole housing because you could'nt swap just the gears. I was going to do this when I first go my car but I was told this.. any links to sites?
Old Mar 15, 2008 | 06:09 PM
C5UL8R's Avatar
C5UL8R
i run 13.2s to 13.5 depending on weather now but i expect that to change
Old Mar 15, 2008 | 07:39 PM
Mike Mercury's Avatar
Mike Mercury
It's not that you can't... but "shouldn't" swap the internal gears. It's not a shadetree mechanic DIY type of project. Many specialized tools and heavy reliance on first hand experience are needed.
And because of the extensive R&R of the carrier... you want to get this right the first time.
Old Mar 16, 2008 | 04:31 AM
fuel_junkie
so whats more cost effective, letting a reputable shop do the swap or buy the housing?
Old Mar 16, 2008 | 10:50 AM
Mike Mercury
all you can do is compare prices for similar offerings.
you can purchase a brand new GMPD 3.42 Z06 carrier for around $1100 - $1200.
when comparing this price to aftermarket shop conversions... make certain you compare apples to apples. The GM Z06 3.42 does not have hardened output shaft(s); which isn't really necessary IMO unless you're an avid dragracer running higher HP and/or drag radials. But if you are an avid dragracer, then you'll want a carrier with the updated hardened output shaft(s).
Old Mar 17, 2008 | 04:32 AM
C5UL8R's Avatar
C5UL8R
do you know where to get a good deal on those, do you need both sides? i
Old Mar 17, 2008 | 08:25 AM
Mike Mercury
I'd call DTE in Fort Wayne, Indiana.
To Gear swap
Old Mar 17, 2008 | 12:44 PM
C5UL8R's Avatar
C5UL8R
thanks , do you recomend that that for all who drag race or just heavily modded cars
Old Mar 17, 2008 | 03:22 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
As others have posted, the rule of is 500miles and no WOT. Plus you should change your fluid.
However,
If you buy a completed pumpkin from GM (either the standard 3.42 or Z06 3.42) there is no break-in required. They come already broken in from the factory.
The break-ins are only necessary when the actual gears are swapped in your unit.
Still, even buying a new pumpkin, I'd take it easy for a while.
Old Mar 17, 2008 | 06:01 PM
C5UL8R's Avatar
C5UL8R
However,
i guess i should have said before it is the zo6 unit, so would a drive from ohio to florida be enough before i drop the hammer
