98 C5 oil leak.
Old Mar 13, 2008 | 05:09 PM
Midwest Vette's Avatar
Midwest Vette
Default 98 C5 oil leak.
I have a oil leak that is mainly on the bottom of the A/C compressor. The oil is very light orange in color. I looked at the engine oil & P.S. fluid to compare colors, they are both darker in color. I have never seen a A/C compressor leak oil before. I do have to recharge the system every year, so there is a slight freon leak. Is there enough oil in the system to drrip off and leave small puddles on the floor?
Old Mar 13, 2008 | 07:41 PM
c5streak's Avatar
c5streak
I'm betting you lost a seal on your A/C comp. I think the total system holds about 9 or 10 oz of oil, but the compressor will have about 2-3 oz. Can you tell where the oil is coming from. It could be the o-ring seals where the aluminum lines bolt up on the rear of the comp. Or the front seal behind the pulley. If it's leaked enough to leave a puddle, it's probably about dry.
Old Mar 13, 2008 | 09:29 PM
Plasticfan's Avatar
Plasticfan
The oil in our AC systems is crystal clear when new. It could pick up an orange tint from the system. Usually those leaks collect so much dirt you can't tell. How big are those small puddles? You can always add oil to the low side. It comes in a small can with 2oz oil and 2oz refrig.
Old Mar 13, 2008 | 10:57 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You are going to have to replace it sooner or later. Might as well get it done before the summer hits. Any AC shop can verify it for you. Got an extra compressor if you wish to buy it.
Old Mar 14, 2008 | 12:21 PM
Midwest Vette
I have not pin pointed where the leak coming from yet, I am going to look at it again today.
Thanks for the reply.
Old Mar 14, 2008 | 12:26 PM
Midwest Vette
One puddle is about the size of a quarter & the others are just drips.
I will keep that in mind. Thanks.
Old Mar 14, 2008 | 12:32 PM
BlackZ06's Avatar
BlackZ06
Orange ?????
You sure it isn't engine coolant ???
The coolant in your car should be Dex-Cool, which is orange.
Old Mar 14, 2008 | 12:51 PM
Midwest Vette
Originally Posted by BlackZ06
Orange ?????
It is a lot thicker than Dex-Cool. I thought the same thing when I saw it.
Old Mar 15, 2008 | 10:55 AM
Midwest Vette
Default Leaking A/C compressor.
I looked at it more yesterday, the front & rear areas of the compressor are dry. the oil is on the bottom & middle of compressor. I am thinking it may be leaking where the case is joined.
Old Mar 15, 2008 | 07:14 PM
TTK98's Avatar
TTK98
That is a common failure on these compressors. There are two o-rings which seal the case halves. I have heard of some people tightening the case bolts to re-seal the thing. You could prove that theory with a dye check kit (bottle of oil w/ dye & penlight blacklight), or take dgrant up on his offer before it scatters & polutes the entire system.
To 98 C5 oil leak.
