Cannot locate turn/emerg flasher unit, please help
Old Dec 8, 2001 | 05:12 PM
Bob Caffey's Avatar
Bob Caffey
Default Cannot locate turn/emerg flasher unit, please help
Just had a shop install the led tail lights in my 01 c5. after a few days i noticed the flashing was very rapid. Today the lights come on but no flashing(turn or 4 way). where is the flasher located? and has this been a problem for others? Is the flasher special for the led lights? :confused:
Old Dec 8, 2001 | 06:55 PM
Plastic Pig's Avatar
Plastic Pig
Live Free or Die
From: One thing is for sure this kind of discourse and BS would not be tolerated on the NCRS forum. Ohio
Default Re: Cannot locate turn/emerg flasher unit, please help (Bob Caffey)
The flasher is integral to the hazard switch. You have to remove the dashpad to get to it.
You can diagnose it with the repair manual and a test light.
Old Dec 8, 2001 | 08:23 PM
Bob Caffey's Avatar
Bob Caffey
Default Re: Cannot locate turn/emerg flasher unit, please help (Duntov-097)
Thanks for your reply, I am confused I know the led tail light replacments came with a new flasher to replace the factory unit. I don't have a manual can you explain or direct me to where i need to go thank's bob
Old Dec 8, 2001 | 08:33 PM
MDT's Avatar
MDT
Bob,
Since the problem arose so shortly after the install, it seems reasonable to me to take it back to the shop that did the installation. May not be the flasher unit at all.
Good luck.
Mark
Old Dec 8, 2001 | 09:13 PM
Plastic Pig
Live Free or Die
Default Re: Cannot locate turn/emerg flasher unit, please help (MDT)
Bob,
Good luck.
Mark
I would try the above route first.
Bob
To Cannot locate turn/emerg flasher unit, please help
