Tire Presss Sensor Problem
Old Mar 16, 2008 | 07:23 PM
Nick1's Avatar
Nick1
Default Tire Presss Sensor Problem
Got a flat tire today, glad I have the run flats.
Plugged the tire and now the TPS is stuck at 28 psi.
My tire gage says 40 psi. After driving a bit, it is still stuck at 28 psi. I went through a couple of on off cycles already, all else seems ok.
Any thoughts on this? Thanks
Old Mar 16, 2008 | 07:57 PM
Oldvetter's Avatar
Oldvetter
Measure your other side tire, the TPSs may have been switched. I doubt this, as it probably lead to your discovering which tire was flat.
Try running over some rough road or a railroad tracks.
Old Mar 17, 2008 | 09:19 AM
jarsdad1's Avatar
jarsdad1
...and let some air out of your tire(s) while you're at it.
Old Mar 17, 2008 | 08:37 PM
Nick1's Avatar
Nick1
Thanks guys, I did let some air out this morning and all is well. Man was it difficult to get the awl through the nail hole and double goes for the plug. That's not coming out ever!
Old Mar 17, 2008 | 08:56 PM
glkfam's Avatar
glkfam
How about reprogramming all four tire sensors and see if that doesn't fix it.
To Tire Presss Sensor Problem
