How does the DIC determine oil % ?
Old Dec 8, 2001 | 10:52 PM
ZAP's Avatar
ZAP
Default How does the DIC determine oil % ?
Anybody know? What's the average miles between 100% and 0% ? :cheers:
Old Dec 8, 2001 | 11:44 PM
The Batman's Avatar
The Batman
Default Re: How does the DIC determine oil % ? (ZAP)
My guess: revolution count. The harder you drive, the more RPM's, the faster oil life diminishes. There's gotta be some kinda fudge factors for temperature and time, too, but the basic metric is revolutions, i.e. at high temperatures, each rev is multiplied by some greater than one scaling number, after so many number of hours of operation, some calculated number of revs is added to the revolution count.
Just a guess...
Old Dec 8, 2001 | 11:54 PM
LoneStarFRC's Avatar
LoneStarFRC
I remember reading some of the parameters in the shop manual but it's been awhile. Some are, temp.,time,mileage,etc. My DIC (er, Johnson Readout) was averaging 3000 mi. to 50% reading. Since that's when I changed oil, I chose to use 50% as my personal "0%". :)
Old Dec 9, 2001 | 12:16 AM
Jim Kramer's Avatar
Jim Kramer
Default Re: How does the DIC determine oil % ? (Tx99FRC)
I also use 50% as my personal 0%.
I had heard that the computer takes into account engine temp, length of trips, average speeds (city vs hwy), and mileage to determine the distance between oil changes.
-Jim
Old Dec 9, 2001 | 12:17 AM
C5 Hardtop's Avatar
C5 Hardtop
My average is about 3700 miles when it sets the indicator light @ 10%
I have tested the oil 3 times at that point and its still good :cheers:
GM knows a thing or two about a thing or two! The only thing it doesn't take in account is dust. Its always raining here so that is a non-issue in the winter!
Joel
Old Dec 9, 2001 | 01:24 AM
Richin Chicago's Avatar
Richin Chicago
It's been some time since I read this but the computer starts off with a "long end number" of somewhere around 7500 miles (15,000 on the 2002?) and then lowers that number if the oil doesn't get to optimal temperature and also lowers it if the oil goes over optimal tempature. As far as I know that is the only 2 parameters used to adjust oil life.
Old Dec 9, 2001 | 06:27 AM
The Batman's Avatar
The Batman
I knew those years of engi-nerd-ing school weren't totally useless...
from http://www.grandprix.net/cgi-bin/97.cgi?file=123.txt :
...the '98 shop manual (page 6-1560) says the PCM calculates
remaining oil life based on total engine revolutions AND calculated engine
oil temperature for each startup since the oil life monitor was reset...
Actually, I make my living writing software, nowadays mostly real-time embedded software. Usually, you want this stuff to be simple, so just counting revolutions has to be the main metric. If I were writing the software, I would assume mileage would figure very little or nothing in calculating engine oil life. You can sit in traffic for hours at a crawl and record small amounts of mileage. Mileage is not an accurate profile of engine oil use. Or at least not as accurate as keeping track of engine revolutions and temperature, which to me, portray a much more accurate picture of engine use. But don't take my word for it. I know nothing about GM software, so I am pretty much talking out of my somewhat educated butt. :lol:
Old Dec 9, 2001 | 01:09 PM
jawski's Avatar
jawski
4800 miles from 100% to 10%
Old Dec 9, 2001 | 01:20 PM
Richin Chicago
Default Re: How does the DIC determine oil % ? (jawski)
Sunds like you either had a lot of short trips or some "spirited" driving?
Old Dec 9, 2001 | 10:41 PM
Dave68's Avatar
Dave68
3000 miles between 100% and 50% (in 6-months of use).
Old Dec 10, 2001 | 01:36 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Re: How does the DIC determine oil % ? (Dave68)
Mine took about 3,000 miles to get down to 50% life remaining when I was driving a mix of local and highway; but a long road trip, even with lots of floor-it passing, cruising at 110, etc took 8,000 to get down to 50%.
Old Dec 10, 2001 | 07:37 PM
l2vette's Avatar
l2vette
I remember somewhere reading that the DIC also measures the number of start/stop cycles of the motor.
To How does the DIC determine oil % ?
