Diablo Predetor help...
Old Mar 18, 2008 | 12:55 PM
lil vette's Avatar
lil vette
Default Diablo Predetor help...
I have the Diablo predetor & had my car dyno'd by a shop.
I would like to learn how to work this thing, but I am worried about pluggin it in & making a mistake. I don't need to change anything just want to "Explore & Learn."
Where can I get easy (lots o pics) directions to learn to operate this & don't accidently change any parameters.
Or, am I making a big deal out of experimenting.
Old Mar 18, 2008 | 07:45 PM
lil vette's Avatar
lil vette
ttt
Old Mar 18, 2008 | 07:50 PM
Mike Mercury's Avatar
Mike Mercury
A couple things come to mind quickly...
1 Guessing you have an A4; I wouldn't double-up with tranny changes via the Predator ... along with the Transgo shift kit.
2. Since you had a dyno tune; why are you then wanting to use the Predator? You'll only muff-up the dyno tune - unless - UNLESS the dyno tune was dine using your predator. But even then, you can make no further fuel table enhancements over what the dyno tune gave you.
3. Most people use a Predator or Hypertech instead of a dyno tune or shift kit.
what are you thinking you can accomplish with the Predator, over the other things you've already done ?
Old Mar 18, 2008 | 08:23 PM
lil vette's Avatar
lil vette
I want to change idle from 550 to 650 & I just like to know how to work the thing. Inquiring minds MUST know.
Old Mar 18, 2008 | 08:29 PM
Mike Mercury
gotcha
My Predator was the first model available for the C5... and I don't think it allows me to adjust the idle speed; though the newer models do.
Considering what you've already had done to your C5; do not... repeat do not load the Predator performance tune. It will over-write the dyno tune and your Transgo might not appreciate any help from the Predator.
On my early model Predator; it forced one to load the preformance tune into the PCM before it allowed you to do anything. I do believe the newer models allow you to skip that step.
Maybe someone will chime-in that has one of the newer models.
Old Mar 19, 2008 | 01:32 PM
C5Natie's Avatar
C5Natie
Originally Posted by Mike Mercury
gotcha
I have the newer Predator model. You can play with parameters without messing anything up. You can always go to the reset parameters section to return them to normal. Idle speed change should be very easy. Go to "Idle RPMs" and up the scale, press ok and done. As long as you dont go and start messing with spark advance and fuel parameters without knowledge you should be alright. You can have your dyno tune saved on the Predator and modify it if you want just make sure you always save your stock tune in case you ever need to go back to it.
Hey Mercury, I know why your avatar is a pic of you. With tech stuff people always trust a guy who looks like Doc from Back to the Future! j/k
Old Mar 19, 2008 | 01:54 PM
timemender's Avatar
timemender
Originally Posted by C5Natie
.....................Hey Mercury, I know why your avatar is a pic of you. With tech stuff people always trust a guy who looks like Doc from Back to the Future! j/k
I thought it was to frighten and intimidate..........
(I'd put up my mug - but I don't want to crack everybody's monitor)
Old Mar 20, 2008 | 01:43 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Diablosport has a helpful forum that can provide the info you seek. Although I wouldn't be tweaking with the dyno tune but you can do some live monitoring and see if it's doing all it capable of.
Old Mar 20, 2008 | 04:29 AM
gpracer1's Avatar
gpracer1
Its very easy to adjust just one or two things. You can even back up your tune to a pc file on you computer as a backup incase you hose it up.
When it asks at first with what do you want to do, go to modify tune.
To Diablo Predetor help...
