Sway Bar upgrade?
Old Mar 19, 2008 | 12:25 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default Sway Bar upgrade?
This month is all about handling. Thus far I've tossed on a new set of Toyo Proxes 4 tires (that stick like nothing else I've ever had) and Bilstein sport shocks to replace my F45.
The car definatly sticks to the ground more but I have a noticable amount of body roll (even though the tires stay on the ground)
I will probably never track the car, but I'd like to stiffen up the rolling. Would ZO6 sways with metal end links do the trick or am I going to need somthing more?
Old Mar 19, 2008 | 06:15 AM
LoneStarFRC's Avatar
LoneStarFRC
It depends on how far you want to go in increasing your roll stiffness. Another option would be to go with the Z51 bars which are larger than your stockers.
I have a set of Z51s w/bushings that are take-offs from my car when I went with the Z06s since I wanted maximize the roll stiffness on mine. I'll make you a good price if you're interested and I'm local too so no shipping. PM me if you're interested. I would definitely recommend the metal end links regardless of which bar(s) you choose.
HTH,
Robert
Old Mar 19, 2008 | 07:30 AM
byte_me's Avatar
byte_me
C6 Z51 bars, bushings and end links- yep...I said C6. There has been a great debate about this and one of the vendors (Pfadt actually) that makes coilovers for vette's suggested this route. They are cheaper then new C5 Z06 bars, bushings and end links and offer larger diameter bars. The quote used was "a more equally balanced feel" one would get going with these bars.
I am doing a suspension mod myself- I just got my Z06 springs shipped to me and was going with Bilstein Sports and C5 Z06 bars until I read that thread....
Do a search for them in C5 tech and take a look at the info...they are approx $100 cheaper then the C5Z bars and are larger
Old Mar 19, 2008 | 08:08 AM
ecoman's Avatar
ecoman
HTH,
Robert
interested in rear sway bar left pm.
Old Mar 19, 2008 | 09:34 AM
JEEP/C5's Avatar
JEEP/C5
I also upgraded to the c5 z06 bars and they made a difference. It was not night and day difference since I had the z51 bars. I wonder how much difference there stepping up to the c6 z bars. What is the diameter?
I also have my old z51 bars (front and rear). Send PM
Old Mar 19, 2008 | 10:05 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
aren't the Z51 bars thicker and thus stiffer?
Old Mar 19, 2008 | 10:53 AM
byte_me's Avatar
byte_me
info taken from the other suspension thread- note the C6 Z51 bars size over the C5Z06 bars...larger and cheaper...
Old Mar 19, 2008 | 10:56 AM
z06801's Avatar
z06801
pfadt adjustable bars and coilovers. get it just how you want it. it is going to be my first spring mod. lonestarfrc that pic of the first witch is awesome
Old Mar 19, 2008 | 11:34 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
are the C6 Zo6 sway bars also a direct swap for C5 cars?
Old Mar 19, 2008 | 11:40 AM
thetaxman's Avatar
thetaxman
I believe the front is the same size
Old Mar 19, 2008 | 02:14 PM
byte_me's Avatar
byte_me
from what I have read- yes...there was a guy who responded stating he had it on his C5. The front is the same, it is the rear that is thicker thus making the ride a bit more stiff. Most agreed that the C6 Z51 was the best all around setup though...That's the route I am going as well.
Old Mar 19, 2008 | 02:34 PM
MJD's Avatar
MJD
Would using poly bushings make any impact?
Old Mar 19, 2008 | 02:38 PM
AU N EGL's Avatar
AU N EGL
Stiffer suspension is NOT ALWAYS better. Suspension systems are designed for each application.
The T1 on normal bumpy roads is a PIA. Rock would be softer.
Old Mar 19, 2008 | 03:35 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I'm thinking Z51 is the least expensive and most effective route for my goals.
Old Mar 19, 2008 | 05:22 PM
AU N EGL's Avatar
AU N EGL
There you go. and I happen to have a slightly used Z51 suspension sitting in my basement, if you interested pm me.
Bars
Springs
Shocks
Old Mar 19, 2008 | 05:35 PM
Rag-Top Rick's Avatar
Rag-Top Rick
On the street, as a rule, if you stay with "stock springs" a large sway bar is a good way to go and is the least expensive mod to try first.
Now adding different springs or tracking the car changes the equation!
Old Mar 19, 2008 | 05:43 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Are the metal end links the same for the Z51? I can't seem to find corrisponding GM part numbers.
To Sway Bar upgrade?
Old Mar 19, 2008 | 05:46 PM
AU N EGL's Avatar
AU N EGL
PM returned
Black 03 Z51 - Blue T1
Old Mar 19, 2008 | 08:25 PM
LoneStarFRC
PM returned.
Old Mar 19, 2008 | 09:02 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Unfortionatly I won't be able to get sway bars anytime soon. I lost one of my jobs tonight and won't have play money for a few weeks at best.
