Zero to sixty with *regular* gas ?
Old Mar 20, 2008 | 01:21 PM
Milacron's Avatar
Milacron
Default Zero to sixty with *regular* gas ?
According to the manual, premium is (of course) recommended fuel for LS1 but using regular is acceptable, with expected loss of performance. I presume the computer alters the timing automatically to prevent knocking issues. But the big question to me is, how much loss exactly ?
Wondering if any magazine, like Road & Track, Consumer Reports, etc has ever done tests to put actual figures on this ? Would be fascinating to me to take same vehicle and do three seperate runs of 0-60 times with 87, 89 and 91 octane gas.
Old Mar 20, 2008 | 02:06 PM
87SAM's Avatar
87SAM
If you’re thinking of cheaping out, don’t bother. Potential problem versus a few cents of savings is not worth it. As far as comparisons, I seem to recall someone doing it (either C4 or C5) but it don’t remember the numbers.
Old Mar 20, 2008 | 04:35 PM
Milacron's Avatar
Milacron
My inclination is to compromise with 89 octane but regarding the "few cents" savings, it would be about $3.75 per tankful or $200 per year assuming 20K miles per year to use 87 vs 91 octane.
Which I admit, still isn't enough savings to justify, if there is confirmed chance of serious potential problems. But when you say "potential problems" without spelling them out exactly, I get the impression you are just guessing really.
If anyone here knows of confirmed problems with using regular long term (or 89 for that matter), fire away...
Having said that, I'm really more curious to hear if the acceleration tests I mentioned has been done or not rather than get into arguments about the practicality of actually using regular gas in a C5 Vette.
Old Mar 20, 2008 | 04:45 PM
LBear's Avatar
LBear
There are NONE. The cars are so high-tech and tuned that you can run 87 octane all day and for the rest of the time you own the car. The computer will instantly detect any "knock" and drop timing.
As a matter of fact, the FACTORY TUNE on these cars is VERY CONSERVATIVE. You can gain 10-20HP at the crank from just tuning the car for more aggressive timing.
Cars back in the 70s, 80's can and did have issues as they had no computer knock sensors and the technology wasn't there. Then yes, you would have issues with running low octane in a high compression engine.
Old Mar 20, 2008 | 04:53 PM
87SAM's Avatar
87SAM
Milicron, there are plenty of threads on this, just do search. It's an often debated subject and you'll be able to make your own decision (no since stirring the pot again).
Old Mar 20, 2008 | 05:07 PM
Milacron's Avatar
Milacron
OK, but as I said that's not my primary interest. My primary interest is simply actual performance figures with each octane in identical circumstances, be it zero to sixty runs, quarter mile runs or whatever.
Old Mar 20, 2008 | 06:58 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
This is not a legitimate test.. Because the Ls1/2 is a high compression engine, 10.5 :1 it requires high octane gas. The lowest being 91 octane, but even that in the summer might require octane booster,, while it does say you can use 87 octane and the car wont break, but it is not recommended for this motor. It just to get you to the next gas station. Using this fuel will cause detonation under load. The knock sensors detect knock, this knock detection is caused by engine knock... the detection causes a timing change, but the engine is knocking before this change occurs.. this knocking causes connecting rod bearing failure, and wrist pin damage over time. Severe cases we have seen holes burnt right through pistons.. predominantly Piston # 7, when using regular gas over a long period of time.
Old Mar 20, 2008 | 08:39 PM
LBear's Avatar
LBear
Higher octane prevents detonation. If knock is detected, the computer will pull timing, preventing knock but at the cost of losing HP.
If the owners manual states to run 91 octane, then run that. If it states that you can run 87 but will lose performance. Then it is OK to run it but know that you will be losing performance.
I always ran 91 or 93 octane in my C5. Some areas only carry 91 due to the elevation. With higher altitudes, you have less oxygen, therefore less need to have higher octane.
For each 1,000 feet in elevation gain, you lose 3%-4% HP. For instance, if you are at 7,000 feet elevation, you got about 21%-28% HP loss. You C6 will be making only 290-310 HP at that level. At 10,000 feet, you are at 240HP.
As they say, your engine is a AIR PUMP. That is why turbo's and superchargers work. They are trying to stuff more air in to get more HP. Vararam and the other "ram air" systems use the same principle of getting cold air and more air into the engine.
Old Mar 20, 2008 | 08:45 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Originally Posted by vettenuts
I don't often get involved in these types of debates, but how can someone who has a grand total of 21 posts make that type of comment about someone who helped develop and test the car we are all driving. This forum is, in my opinion, an opportunity to discuss and gather technical information "tech forum", why would you even post something like that?
Old Mar 20, 2008 | 08:54 PM
nickolbag's Avatar
nickolbag
I don't think you need a lot of posts on one forum before you can aquire knowledge on a subject............
That being said, I have heard time and again that octane booster does next to nothing even if you dump in a few cans. I can't see running lower octane hurting performance that much. I also can't see why you would want to run it. The cost vs risk doesn't seem to add up.
Old Mar 20, 2008 | 09:34 PM
B-ras's Avatar
B-ras
Deleted....
If you mean a joke in the sense of adding performance, you're right. Octane in a high compression motor isn't about power, it's about safety.
And ET has forgotten more about the C5 than you'll ever know.
Last edited by Jesse; Mar 20, 2008 at 09:52 PM. Reason: Deleted comment by Milacron as unnecessary...
Old Mar 20, 2008 | 09:51 PM
Jesse's Avatar
Jesse
Retired Admin
Founder St. Jude Fundraiser
To Zero to sixty with *regular* gas ?
