Led Taillight Problems - Help!
Old Mar 21, 2008 | 08:30 PM
Z06forGM's Avatar
Z06forGM
Default Led Taillight Problems - Help!
Anyways, I have had a set of LED taillights on the car for the past 2 years, and they worked perfectly. My left front turn signal bulb goes out and the lights flash fast, like they are suppose to do. I replaced the burned out bulb and the lights still flash fast
Now that I have checked most everthing to find out why the lights are flashing fast with the new GM bulb, I figure it might be a resistance issue. I unplugged one of the LED lights and plug a regular bulb in and the lights flash like they are suppose to. Put the LED's back in, and they flash fast again.
I even checked another set of lights to see if somehow the LED's went bad on me, and the new LED lights do the same thing.
Has anyone else had this problem ? Any suggestions on how to fix the issue and keep the LED's ?
Thanks for any help ya'll can send my way!
Old Mar 21, 2008 | 08:45 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Do a search in c5 gen, you can bypass the OEM flasher and put in one for LEDs. You can also by a harness made up from a supporting vendor so it is plug-and-play.
Old Mar 21, 2008 | 09:45 PM
jdmvette's Avatar
jdmvette
Night Owl for life
yes, buy the LED harness from Richard, C5VetteLS1 and plug an LED flasher on it and you'll never have this problem again.
in fact, you will be able to add LED bulbs to your front DRLs and you still wont have rapid flash. it's a great mod.
Old Mar 22, 2008 | 12:10 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Yep, buy the flasher bypass. Easy install and your LEDs will work again also fixes sequential signals if you have em. I'm a happy customer.
Old Mar 22, 2008 | 02:14 PM
Z06forGM's Avatar
Z06forGM
THANKS GUYS!
I'll look up Richard and go from there!
Old Sep 22, 2008 | 02:24 AM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
Anytime you switch to LED lights for your turn signals you're going to have hyper flash where your lights blink faster than normal. I had the same problem until I installed Load Equalizers and this solved it. I bought them at the Autolumination website.
To Led Taillight Problems - Help!
