Non Run Flat Tires for C5
Old Mar 21, 2008 | 09:01 PM
sumax's Avatar
sumax
7th Gear
Default Non Run Flat Tires for C5
What is the best tire that is not a run flat tire for a C5?
Old Mar 21, 2008 | 10:01 PM
Dave68's Avatar
Dave68
This was published a wile ago, but for the most part, everything applies today:
Although Car & Driver used "only" a 325 BMW as a test mule, you are very likely to experience similar results with your C5. To minimize variables such as driving techniques, track surface temps, etc, C&D enlisted the help of the Tire Rack and their test mule vehicle. Although the track used was small, it's lined with sprinklers that can soak the asphalt. "It took three days to perform all the tests. We accerated to 50 mph and then braked to a standstill. There was a benefit to that lower speed: It ensured that we were measuring the braking performance of the tires and not just brake fade."
"In addition to factoring the wet and dry scores, we gave points based on a tires's price and tread-wear grade, which is a rough estimate of how long a tire will have usable tread." "Our test focused on measuring performance, so we decided that results in the dry-lateral grip, for example - would carry the most weight."
So, without further adeau, here're the results:
(Best to worst):
NUMBER 1: Goodyear GSD3: "As an all-around performance tire, you can't beat this Goodyear. It was the best performer in all three wet-track tests and was very competent in the dry. It generated .94g on the dry skidpad, only .01g off the first place (dry) BFGoodrich and tied with the Yokohama and Hankook.
The Goodyear gripped so well, that you might not have been certain that the road was wet. It held onto the wet track with .82g of stick, an impressive figure considering the worst tire in that test made only .67g.
...And like the Continental, the Goodyear had a high 280 tread-wear grade. Note: An independent testing lab found that these tires last longer than almost all super high performance Summer tires, but especially the inexpensive ($100) tires. At $145, ieach, it's $34 cheaper than the most expensive (guess which tires have THAT distinction!).
2nd place: Continental ContiSportContact 2: "It simply didn't feel as sporty as the others.....on dry surfaces, the Conti never rose above third from last among 11 tires. It felt soft and imprecise. But in the wet, the spread from best to worse was 15 percent, which made for a larger point spread (giving the Contis a boost). Plus the Continental had a 280tread-wear grade that was the highest (tied) for this test.
3rd place: Yokohama Advan Neova AD07: Excellent dry performance, but a bit on the slippery end in the wet stuff - expensive at $175 apiece.
4th place: Michelin Pilot Sport PS2: "At $179, the PS2 is the most expensive tire in the test." Competent, but expensive sums up this tire.
5th place: Hankook Ventus R-S2 Z212: At $99 each, these are the least expensive tires - very good on dry pavement, but "greasy and slow to recover" on the wet stuff.
6th place: Dunlop SP Sport Max: "In the dry, the tire seemed to lose its confidence..."
7th place: Pirelli P Zero Rosso Asimmetrico:"In the dry-lateral-grip test, the Pirelli tied for second to last, and it finished seventh in the dry-braking test.
8th place: Toyo Proxes T1R: "...the Proxes never placed higher than eighth in any test"...nuff said!
9th place: Bridgestone Potenza RE050A: "it felt dull and disconnected and was somewhat soft and imprecise when driven hard."
10th place: BFGoodrich g-Force T/A KD: Outstanding performance on dry surfaces, but very scary on wet surfaces - don't get caught in a rainstorm wearing these shoes...Note: The KD2s are much better on wet roads, althugh they are known to be a bit noisier than most on dry roads.
11th place: Kumho Ecsta MX: "They didn't offer much grip and the time of 30.28 seconds in the dry autocross was .62 second slower than the fastest tire. That may not seem like much, but our course was only 0.3 mille long, and on a longer track, that gap would be commensurately greater." "And although the MX - at $136 per - was the third-least-expensive tire in our test, the high score in the price category wasn't enough to regain ground lost in the performance tests."
On a congratulatory note, the first place tire is made right here in the USA by an American tire company
Old Aug 1, 2023 | 06:53 AM
DreadRoberts's Avatar
DreadRoberts
Navigator
Well it is now 2023. These tires are so outmoded that this comparison is inaccurate to say the least. If someone could do a modern comparison on this site it would be much appreciated.
Old Aug 1, 2023 | 10:29 AM
Missileboy's Avatar
Missileboy
I am running Nitto's NT555 G2's and am very happy with them. It is a summer tire. Works awesome in the wet as well. I wasn't looking for a AS tire since I don't drive the Vette much in the winter.
https://www.nittotire.com/car-tires/...formance-tire/
Old Aug 1, 2023 | 11:28 AM
Dads2kconvertible's Avatar
Dads2kconvertible
Since the word "best" is subjective there is no right answer. There is only 'best compromise for my expected use case'.
What factors are most important? Traction? Tire longevity? Size? Temperature range? Wet weather handling? Price? Some other factors?
To Non Run Flat Tires for C5
