***Ceramic Coating?********
Old Mar 23, 2008 | 11:02 AM
CLHaka's Avatar
CLHaka
Default ***Ceramic Coating?********
I looked through the supporting vendors list, does anyone know who does ceramic coating or Jet Hot type coating of exhaust manifolds?
any help is appreciated...
Old Mar 23, 2008 | 12:00 PM
hotwheels57's Avatar
hotwheels57
If you mean which vendors offer JET HOT (or any ceramic metallic coatings) on their headers, probably most do as an option. You'd have to contact them.
If you mean are their any ceramic metallic coating vendors, I don't think so.
If you're asking about applying a ceramic metallic coating of your oem cast iron exhaust manifolds, try JET HOT or HPC. Both have plants across the USA.
Oh, and if the latter is what you're asking about, expect a few to question your thought process of coating cast iron oem exhaust manifolds. I've done it several times after grinding casting marks and numbers off of them. The coating looks great and it allows you to remove any thin sheet metal heat shielding as another benefit.
It's your car to do with as you please.
Old Mar 23, 2008 | 12:13 PM
CLHaka's Avatar
CLHaka
Default manifolds
yes, I need to have my exhaust manfolds coated for a twin turbo set-up, I have em off, just wanted to see if we has a supporting vendor that offered this service, before looking elsewhere... thanks
Old Mar 23, 2008 | 12:24 PM
LT1GMC's Avatar
LT1GMC
Jet Hot themselves will price it for you ,send you a quote, and take care of your needs a bit cheaper than going thru a vendor. They were very helpful with me earlier this week, and sent me a quote and information pronto. Web search their number or site.
Old Mar 23, 2008 | 01:07 PM
hotwheels57
Just a ball park figure on the cost, it cost me just under $200 to have used sbc cast iron oem manifolds done in JET HOT (inside and outside).
Since I'm in AZ and they have a plant about 100 miles away, it saved me on shipping.
Check their website for the plant nearest you...
Old Mar 23, 2008 | 01:28 PM
Pumba's Avatar
Pumba
Yes, I need to have my exhaust manfolds coated for a twin turbo set-up. I have them off. I just wanted to see if we have a supporting vendor that offered this service, before looking elsewhere... Thanks
Swain Tech coats exhaust components, including exhaust manifolds, with a white ceramic coating "White Lightning" that they state will reduce thermal emissions by approximately 50%. Their web site URL is www.swaintech.com.
I have had my headers, high-flow cats, and x-pipe coated with good results.
To ***Ceramic Coating?********
