replacing e brake clip
Old Mar 23, 2008 | 12:27 PM
corvettescotty's Avatar
corvettescotty
Cruising
Default replacing e brake clip
After hours of trying to get the e brake clip back on and stay on i figured out a way. The little clips that hold the clip in place on the backing plate are shaped like an L i put the spring in the L clip then gently bent that clip in so it was shaped like a J and the spring can't come out but can still move like it is supose to. Then i took a thin screwdriver with a notch in the end and pushed the ends of the spring down into the e brake took obout 30 seconds
