Increase horse power
Old Mar 23, 2008 | 10:15 PM
Keldane's Avatar
Keldane
Default Increase horse power
How do I increase hp for my 2000 frc 6speed?
Rich
Old Mar 23, 2008 | 10:22 PM
mac_05evo's Avatar
mac_05evo
How much power are you looking for? What are you wanting to do w/ the car?? Simple bolt-ons would be a good start though. I'd start with things such as longtubes, cam, intake (or zip tie mod), and a tune.
Old Mar 23, 2008 | 10:26 PM
Tikiman12's Avatar
Tikiman12
start small, like intake and exhaust. then go for the cam and tune. but its all about how much you wanna spend. do a search you'll get millions of these threads, all are very helpful
Old Mar 23, 2008 | 10:36 PM
motogib1's Avatar
motogib1
Horsepower in order of expense and the order folks seem to take:
1. Cold Air Intake - true CAI such as Callaway Honker, Vararam etc
2. Long tube headers with hi-flo cats and x-pipe
3. Tune
These things will give you a decent boost in hp
160 degree stat, aftermarket maf will not boost hp.
Aftermarket exhaust -little power gain but sounds good and most folks have em
4. Gears - no more hp but greater acceleration
5. Cam - good boost in hp but installationis not cheap
6 Aftermarket heads and cam - several k dollars but can produce big hp
7. Forced induction - Can bolt on and get big hp.
A true CAI such as the honker or the vararam combined with a tune will give noticeable SOPT power increase.
Befor you start any modification, learn all you can on the forum. Also read this thread: , New England Green performance primer.
Old Mar 23, 2008 | 10:58 PM
black98c5's Avatar
black98c5
Have a goal in mind and work from there. You have to ask yourself what you plan on doing with the car.
Old Mar 24, 2008 | 01:32 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Rich
The easiest way to increase hp is to open your wallet at the nearest corvettte tuner. They'll do the rest....
Old Mar 24, 2008 | 08:05 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Rich
MONEY
Old Mar 24, 2008 | 09:38 PM
motogib1's Avatar
motogib1
MONEY
Unfortunately yes, how much hp you can get = how much money you have to spend. Still, you want to get the most bang for the buck, so knowledge is the key unless you are flush, then just go to the tuner and tell him how much hp you want.
Old Mar 27, 2008 | 08:57 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Originally Posted by motogib1
Before you start any modification, learn all you can on the forum. Also read this thread: , England Green performance primer.
Thanks for the Kudos.
Stephen
Old Mar 27, 2008 | 09:16 AM
DefenderC5's Avatar
DefenderC5
(Insert Performance Hood Seal post here)
Old Mar 27, 2008 | 10:15 AM
MagRedConv's Avatar
MagRedConv
3. Tune
This one should really be a sticky.
Old Mar 27, 2008 | 08:48 PM
American Hydrocarbon
Guest
Posts: n/a
But that's what we do for fun
Old Mar 27, 2008 | 09:43 PM
JPEAK's Avatar
JPEAK
Rich
The easiest way is to pull out your visa, then when maxed out, get another one and repeat process..
Old Mar 27, 2008 | 11:21 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Zaino and Lloyds mats.
Old Mar 27, 2008 | 11:31 PM
geterdone's Avatar
geterdone
Originally Posted by road pilot
MONEY
Old Mar 28, 2008 | 12:49 AM
spicytuna's Avatar
spicytuna
Slap on some Z06 fender emblems.
Old Mar 28, 2008 | 08:05 AM
AU N EGL's Avatar
AU N EGL
That ratio is exponential
IMO it comes down to Money. How much do you have to spend? Then start taking to reputable builders, England Green aka Stephen has stepped up on this thread, and other forum venders.
Let them know what you have, what you want, and your budget. Then tell them what you want?
The two of you will come up with a plain that works for you the car owner and driver and the engine builder.
Eventfully there is a point when a create motor is less expensive then current motor upgrades.
Good Luck on your project and keep us updated.
Old Mar 28, 2008 | 09:06 AM
Higgs Boson's Avatar
Higgs Boson
I recommend buying mods in cash only. It is VERY easy to get yourself way in over your head when you mix mods with credit. I've done it before and now if I can't pay for it in cash, I just deal with less HP. Just my 2.
Old Mar 28, 2008 | 09:20 AM
99 vett babycar's Avatar
99 vett babycar
how much power do you want and how much money do you have ?
To Increase horse power
