I recently installed the Donaldson air cleaner and cold air shroud on my '02 LS1 with AT. I am experiencing an annoying surging at 1500 rpm under light load and light throttle conditions. Has anyone else had this problem? How was it fixed? Thanks to any who can help...
I never had any problems with the Donaldson Cold Air Cover on my car when I ran it. However, we had a few customers that had the same problems so we stopped carrying the cold air lids. I think it has something to do with turbulant air crossing the wires of the MAF. Make sure that cover is sealed to the shroud real good or you will get air leaking in from under the hood. You do not want this happening because then you have high pressure air entering the filter from beneath the shroud and low pressure air entering from under the hood which can mess up your MAF's air metering.
I think it is all that "dry air" up there in Scottsdale.... Seriously, I think Matt is probably right. Good luck. On another note, someone once posted that his surging improved after he did a computer re-learn. Sounds unlikely, but it might be worth a try. :D
The surging we had was resolved by increasing fuel pressure. It is a very lean surge, low/no throttle. In our case, it was most noticable when driving with cruise control on and going over a hill, almost any size hill that causes the CC to "let up" on the throttle.
Boosted fuel pressure back to 60# and 99.5% of the surging is gone.
Saw another "fix" which was: to put the MAF screen back in. Did you take your's out? As I recall, others had the Donaldson and the cold air lid with surging problems. They put the screen back in the MAF and it was fixed.
I have the Donaldson with the lip and have experienced some "light" surging. Not enough for me to remedy however.
Surging is usually indicative of a lean condition. Check to make sure there are no vacuum leaks associated with the induction tube....especially around the MAF and Throttle Body. Things may improve as you drive it and it relearns.
I don't have the Donaldson but I did install the Twin-Flow Intake a few weeks ago on my 2002 coupe. (I also slept at a Holiday Inn last night. :jester )
I'd heard of surging problems on '01-'02's with aftermarket intake systems and was expecting to have the same. I didn't. I left my MAF screen in and did an idle relearn. Perfect so far.
Gary, please give us a call and we will (while driving) Autotap your car.
Surging because of the cold air cover on a Blackwing is ridiculous. :lol:
Lean condition causing surging is a possibilty. If we can get Gary to come in, we will post our findings to the forum.
Doug Rippie himself told me to take the screen off the MAF with the Donaldson.
Doug Rippie.......himself.........interesting ...........there seems to be a conflict of opinion at DRM..........so do you have the surging with the cold air lip?
From: HOPE is the first step on the road to disappointment.
Re: Surging with Donaldson cold air (Phantom1000)
This may be the difference since I DO NOT have the cold air lip. But I was at Rippie's shop about 3 weeks ago (I live 15 miles from him) and he told me that with a Donaldson I should remove the screen on the MAF. I will probably do this next spring. So far I have 13,000 miles on the car with the Donaldson and no problems at all.
The 2 causes I've heard of is an air leak (check all connections carefully) or removing the MAF screens. I did have surging when I used a ported MAF with the screens removed. I've since put the stock MAF back in and no longer have any surging.
