2004 A4 non starting
Old Mar 24, 2008 | 10:29 PM
char52les's Avatar
char52les
6th Gear
Default 2004 A4 non starting
After checking battery wires & replacing the battery, my 04 still would not start.....had it sent to the local dealer....apparantly it needs a new ignition module. Seems they have to go in through the steering column and then reprogram all the ignition stuff. Including the tow, I'm looking at $600. Does this seem correct?
Old Mar 25, 2008 | 01:41 AM
Blown 346's Avatar
Blown 346
Maybe for the dealer than $600 seems right. I had the same problem with my 2000 Camaro. I had the whole ignition module replaced and a set of 2 new ignition keys, installed done for $250 at a local shop.
Old Mar 25, 2008 | 02:18 AM
2000BSME's Avatar
2000BSME
My vette wouldn't start and it turned out to be the head ground wire. I had to find it myself though, as the dealer grease monkeys showed only incompetence when I took my car to them.
Old Mar 25, 2008 | 04:38 AM
BlackZ06's Avatar
BlackZ06
An "ignition module" on the steering column ????? "Reprogram the ignition stuff" ???? Be sure they replace your muffler bearings and check your blinker fluid level, it's the least they can do for $600.00
Old Mar 25, 2008 | 06:10 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
char52les >> If you'd fill in your profile info you may get a lot more help if people know where you're located
Old Mar 25, 2008 | 10:04 AM
char52les's Avatar
char52les
6th Gear
Thanks..I didn't think of it. I'm in Maineville, Ohio..just north of Cincinnati...the dealer is Terry Lee Chevrolet.
Old Mar 25, 2008 | 10:50 AM
mrm1149's Avatar
mrm1149
Hopefully someone down around Cinci will see this post and recommend a facility to you.. Your dealer almost sounds like they're talking about the ignition switch which shouldn't be anywhere near a $600 item
Old Mar 25, 2008 | 01:39 PM
Pro Street's Avatar
Pro Street
My guess is they are wanting to replace the BCM and reprogram the BCM.
Old Mar 25, 2008 | 04:08 PM
Blown 346's Avatar
Blown 346
I believe he is referring to the actual ignition cylinder.
Old Mar 25, 2008 | 11:24 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
HOLY CRAP! Ignition module?????????????????? We dont have ignition modules. Are you SURE your saying the exact same thing they ststed?? If so, the person who told you that hasnt a clue.
To 2004 A4 non starting
