OCTANE BOOSTER UNLEADED
Old Dec 10, 2001 | 10:32 AM
davidmax's Avatar
davidmax
Default OCTANE BOOSTER UNLEADED
Has any lucky soul at any price(at 4.69 per gallon for 100octane isnt exactly cheap)found a true octane booster for unleaded fuel that yields results,even if it costs 20.00+ to treat a tank it would be nice to take on trips where sub 90 octane is the norm.With my new adjustable boost set up I can adjust out detonation to the point 87-89 would work fine but,I would have a HP drop thats very noticeable and I would like to run at least 7.5-9 Lbs.cross country and keep my ponies up there,with an octane booster for all our blown and HI-Compression motors.Sure Hope Our Troops Get Home Soon SAFE and with HONOR and DIGNITY!!!!!! Have a Wonderful day and treat life NICE!! David S.
Old Dec 10, 2001 | 11:53 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: OCTANE BOOSTER UNLEADED (davidmax)
Ive heard of some unleaded octane booster made in australia that acutally was the only booster that tested to over 100 I beleive. Not sure of availability in US.
Old Dec 10, 2001 | 11:57 AM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In IV Veteran
How high compression are you running? You installed a Supercharger and instead of lowering the compression, you raised it? 7-9 psi on a stock motor is getting to the limit, without raising the compresseion.
What Supercharger are you using and how are you adjusting boost with out changing pulleys? Boost adjustability is usually in turbo charger application...
Old Dec 10, 2001 | 12:03 PM
Godspeed's Avatar
Godspeed
Senior Member
Default Re: OCTANE BOOSTER UNLEADED (Godspeed)
Turbo 108
http://store.yahoo.com/corvetteforum/tur108racfue.html
Old Dec 10, 2001 | 12:09 PM
kewlbrz's Avatar
kewlbrz
David, see this site regarding octane booster independent tests:
http://www.fbody.com/members/stevenm...ne_booster.htm
Old Dec 11, 2001 | 01:38 PM
davidmax's Avatar
davidmax
G-DSPEED I'm running a 13lb Twin turbo adjustable and trading in my LS-6 for a C5-R 427 CI.When I turn up DA BOOST I NEEDS DA OCTANE,I dont what made you think I was running a SC set-up that will be next year hopefully on a real big block.Take it Fast David S.
To OCTANE BOOSTER UNLEADED
