2001 suddenly died on freeway! HELP!
Old Dec 10, 2001 | 02:24 PM
rmasu's Avatar
rmasu
Default 2001 suddenly died on freeway! HELP!
Fellow members help me out, I have a 2001 Z06 4000 miles no major mods. I was driving in heavy traffic on the freeway, while rolling about 5-10 mph the car suddenly dies, the lights stayed on, but the tach went to zero and it would not turn over, I tried to turn it over and it would crank, but not start, I tried this as I was rolling witht the clutch in. I finally pulled over and pulled the key out, I stuck the key back in and it started right away. I drove to my christmas party and home (no traffic) with no problems. All the presets for radio etc were the same, but the oil lifer meter went to 100% when it was at 40%. I drove the car again last nigh with no further problems, any ideas? Has this happened to anyone before?
Thanks all.
HAppy holidays.
Doc. Ross
Old Dec 10, 2001 | 02:29 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Default Re: 2001 suddenly died on freeway! HELP! (rmasu)
Bad battery connection maybe. I had the same thing happen to me. I also see you have a aftermarket stereo like me. Turns out the battery connection was loose I tighten it and it has never happend again. The Gauges went wacko and the car died. Check the connection.
[Modified by Wicked C5, 10:30 AM 12/10/2001]
Old Dec 10, 2001 | 02:33 PM
SeaFive's Avatar
SeaFive
Have you checked the DIC for any codes it threw?
Old Dec 10, 2001 | 03:39 PM
rmasu's Avatar
rmasu
Default Re: 2001 suddenly died on freeway! HELP! (Buckmaster)
Hmmm, never thought about the battery connection, I will check that out! I will retrieve the codes tonight, is the process in the the manual? After I retrieve the codes how do I interpert them? Thanks again!
Happy holidays :flag
Doc Ross
Old Dec 10, 2001 | 04:03 PM
NoMercy's Avatar
NoMercy
Hey Doc!! Sometimes these cars have "stupid attacks"! My 00 vert had a similar problem. Once I restarted it had no problems, and it never happened again. :confused: :confused: :confused:
Old Dec 10, 2001 | 05:10 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
It almost sounds like, pull key, wait 10 seconds, similar to C/L but not really. For some reason, it sounds as if you did not get fuel for an instant.
Old Dec 10, 2001 | 07:59 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: 2001 suddenly died on freeway! HELP! (wallstAL)
Pulling DIC codes:
0. Have pen & paper ready
1. turn key on and let message cycle through (Vette by Chevy)
2. press and hold the options button down.
3. press the fuel button rapidly 4 times.
4. right down the codes and make a post for explaination or IM/e-mail me.
codes that have a trailing "C" or "H" after them indicate a Current or History code.
Just found this in another post, I may be ov some help and has some codes listed. http://home.att.net/~jansseng/DTC_Codes.htm
[Modified by Gary2KC5, 6:03 PM 12/10/2001]
Old Dec 11, 2001 | 05:10 AM
rmasu's Avatar
rmasu
Big Mahalo to Gary and Bill and all who posted a quick reply! I am gonna try and retrieve the codes tomorrow. I hope this was an isolated gremlin :troll :troll
Thanks again!
Doc
Old Dec 11, 2001 | 07:52 AM
black thunder's Avatar
black thunder
I had a similar problem when I first got my car. It would die unexpectedly and then after a couple of minutes would start and be OK for a while until the next time.
Went to the dealer and they replaced all kinds of sensors and etc. but the car still died. I finally asked them to replace the PCM. They said, it could not be that!!!!
Went to another dealer-- they immediately replaced the PCM, -- car has been fine ever since!!
Old Dec 11, 2001 | 12:52 PM
UDLOSE's Avatar
UDLOSE
Happened to me afer the cloumn lock recall was done. The alarm (key fob) wire came loose and killed the engine.
That month GM had my car for 3 weeks out of the month. All kinds of stuff broke, they even scrached the car and had to repaint part of it.
I hate the way GM treats Corvette owner! Treat us like we bought a 10k pickup.
Old Dec 11, 2001 | 01:53 PM
ersatz928's Avatar
ersatz928
Default Re: 2001 suddenly died on freeway! HELP! (UDLOSE)
Check for tight connections at BOTH ends of the +(to the starter) and - battery cables, and the large red wire at the alternator.
To 2001 suddenly died on freeway! HELP!
