I cannot get my floor jack up under the car enough to reach the jack points listed in the manual. Can I jack from the jacking point behind the front wheel, without a "jacking puck"? I do have a rubber padded jack plate, so marring is not an issue.
Is there any other place I can jack from, to get to the trans?
Re: Installing !CAGS... where do I jack from? (cj)
I made some ramps and did mine by crawling under from the back. Figured I needed them to change the oil anyway. Used some old 2X12's I had in the basement.
