average temps for a c5
Old Mar 25, 2008 | 10:34 PM
talon46's Avatar
talon46
Default average temps for a c5
I just bought my vette no codes, but what is the average temp at idle if you were to idle for more then 10-15 minutes or like in heavy traffic.
Mine creeps up well over 200 degrees about 3/4 of the way on the gage, did not come close to the red but it still got hot.
started moving and it came right down under 200 degrees.
I am pretty sure it got to about 220-230 maybe 240 will have to look at the gage. the gage seemed to do what my hot rod did if it was or is running hot and you turn on the lights the gage moved a big more to the right. I never figured out what caused that in my hot rod.
Let me know what it should be doing
thanks
james
Old Mar 25, 2008 | 10:37 PM
corvettejoe98's Avatar
corvettejoe98
wow haha thats hot, I have a 160 thermostat and many bolt on mods and "hot" in my car is 180-190 ish in traffic. She usually chills around 170-178. Runs like a beast too.
Old Mar 25, 2008 | 11:12 PM
chris308's Avatar
chris308
mine holds steady at about 220 sitting at a light.
Old Mar 26, 2008 | 12:22 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Mine used to hit 220 at a drive through. Then I swapped a 180 thermo and reprogrammed my fans. Now it hasn't went over 198 yet. At speed it maintains 188-190 Kinda wish I went with a 160 but summers coming and we'll see.
Keep in mind that the cooling system is designed to cool with movement of air under the car. Standing still you depend on the electric fans and what ever temp air they can pull. ie: hot air from the heated pavement and motor heat.
Old Mar 26, 2008 | 01:17 AM
BlackZ06's Avatar
BlackZ06
The stock settings for the fans are ....
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
What you saw is normal behaviour for the car.
Old Mar 26, 2008 | 01:21 AM
GettReal's Avatar
GettReal
I will run anywhere around 200-210 depending on how hot and how slow Im going. Ive heard getting up to 230 isnt too unusual in traffic conditions or super hot days. Oh and I have a black car..yes it makes it hotter.
Old Mar 26, 2008 | 01:52 AM
Bill Dearborn's Avatar
Bill Dearborn
thanks
james
That is about right. The temp can get to about 240 before the fans bring it down. Nothing to worry about on modern cars. Monitor the temp on the DIC as it is more accurate than the analog gauge.
Bill
Old Mar 26, 2008 | 11:21 AM
jbauch357's Avatar
jbauch357
Coolant temp will fluctuate between 190 and 240 during normal driving for me, it all depends on how fast I am moving, how hard I am driving and what the ambient temperatures are.
Oil temperature once warmed up usually doesn't dip under 210 degrees and during normal driving will get into the 250's, when I am really thrashing on it will get up into the 290's.
FWIW I like to keep my DIC set to oil temp since there isn't an analog gauge for it, gives me a better idea of the actual internal engine temps rather than the coolant in the water jacket around the motor...
Old Mar 26, 2008 | 09:07 PM
talon46's Avatar
talon46
Default thanks for the info guys and gals if it applies
Glad to know its not out of whack,
I am getting ready to pull my hot rod in the works off of the lemon lot, people are pissing me off, they are opening my hood and not calling me to say they wanna look. That really really pissed me off, and what makes me mad is they are looky loo's never will buy anything they just wanna oggle it, so tommorrow I will probably pull it off and put my bike up for sale. Gotta love looky loos.
Damn am I wierd or should I expect someone to say hey nice old truck 1950 Ford F1 I wanna check it out more.
ANyways needed to vent drove the vette today absolutley love it.
78 degrees today outside heat, it was lovely.
again thanks glad to know the new toy is working great.
James
Old Mar 27, 2008 | 01:08 PM
kevin40zx's Avatar
kevin40zx
Old Mar 27, 2008 | 02:53 PM
mundo's Avatar
mundo
My '99 will run between 195 and 225. At 226 the fans come on. A good test for radiator effeciency is see how fast the temp come down after the fans come on. It takes a longer time for the temp to come down when driving because the air condensor is in front of the radiator and air is tring to be pushed through it to the radiator. When the fans come on the air is sucked in. My temp will come down from 226 to 210 with in 2 minutes after the fan comes on.
Old Mar 27, 2008 | 06:06 PM
nmbis2k's Avatar
nmbis2k
you might want to consider to have your fan temps set lower. Some one skilled with the computer controls can do this in mere minutes.
I had my fans controller lower about 20 degrees, and my car, and I run cooler.
Old Mar 27, 2008 | 06:12 PM
MagRedConv's Avatar
MagRedConv
I'll see 220 if I'm sitting on a hot day for 10 minutes. Once I clean out underneath and in between I don't think I'll see that anymore.
Old Mar 27, 2008 | 06:13 PM
red88L98convert's Avatar
red88L98convert
what do you mean by 'computer controls'?? is there some way to lower the temps without taking it to a tuner?
Old Mar 27, 2008 | 07:03 PM
Gray Weasel's Avatar
Gray Weasel
Default normal temps
If you havent cleaned out the radatior and air conditioner condenser you will be suprised how much stuff is there small animals paper and plastic bags the front is like a vac.. I put mine up on a lift and use an air hose with a long nozzel to blow the stuff out it will lower your temps as much as 15 deg
Old Mar 27, 2008 | 10:21 PM
middlebrookgt's Avatar
middlebrookgt
I agree. Do some searches on the forum and get the basics complete before it gets hot outside. Clean the radiator, check that the foam and skirts are in the right places so the air is all forced through the radiator. You may want to flush the system, too. Fans kick on around 230F. Many folks change thermostats, lower fan control temps, try different mixtures of coolant/water/additive, install bigger radiators, etc to get the temps down further.
Old Mar 27, 2008 | 10:44 PM
corvettedoug's Avatar
corvettedoug
Most of the time you should be running closer to 210-220 while sitting in traffic and under 200 on highway.
You should never really go over 230-235 sitting in traffic.
Old Apr 20, 2008 | 02:47 AM
Jeffmeister's Avatar
Jeffmeister
Sorry to bring up an old thread but im glad my engine is running nice most of the time under 200, im only over if I really get into it!
To average temps for a c5
