Oxygen sensors
Old Mar 26, 2008 | 08:34 PM
mickey_7106's Avatar
mickey_7106
Default Oxygen sensors
can i just run 4 rear O2 sensors instead of getting extensions for the front? im having a hard time looking for front extensions
Old Mar 26, 2008 | 08:46 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default yes and no
yes you can run 4 rear o2 sensors for the length of the wiring, but to run them in the front positions you need adapters. Most people however just have the rears tuned out and just run the rear 02 sensors adapted to go in the front positions. This is of course if you are talking that you now have headers.....which I assume you do.
Old Mar 27, 2008 | 10:22 AM
mickey_7106
i do have adapters that came with my LG packet..my tuner says i need all 4 to be functional to pass the sniffer test
Old Mar 27, 2008 | 10:48 AM
JohnTheStigGalt's Avatar
JohnTheStigGalt
Don't know the answer to your question, but have a couple suggestions:
American Racing headers use extensions, not adapters... Can't get some from them?
Or RockAuto carries both electrical connectors. You could just make your own...
Good luck,
Vaughn
Old Mar 27, 2008 | 11:20 AM
BlackZ06's Avatar
BlackZ06
You realize the LG headers are not legal in Cali ??? If the tech doing your smog check spots the headers during the visual part of the inspection, you could have a problem on your hands .... some catch it, some don't .... it's a crap shoot ....
Good luck,
Old Mar 27, 2008 | 12:07 PM
jirasvet's Avatar
jirasvet
Contact Anthony at LG motor sports He can hook you up with the right
extensions. They should have the extensions you need. I have an 04 Z
and run all 4 O2's in there original position.
Old Mar 27, 2008 | 12:14 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Good luck,
Vaughn
The AR header system for the C5 doesn't include extensions, nor are they required. The stock lengths fit fine.
To Oxygen sensors
