C5 stalling after turbo install.
Anyone have any ideas?
Thanks.
What is a DTC code?No serves engine light.
Thanks.
To display the DTC data .... go here for instructions .....
https://www.corvetteforum.com/techti...D=26&TopicID=1
BE CERTAIN to list the ENTIRE DTC. They look something like P 1234 H .... we need the first letter (P says it is a Powertrain issue ... B is body ... etc.) the next four numbers are the code (and that's why we need the leading letter because both the Powertrain and the Chassis may have a 1234 code ..... and the last character will be a C (Current) or H (History) showing the status of the code.
Easiest to wait for the DIC display to cycle through to MANUAL MODE, then write the codes down and post .... leave out the codes starting with a "U" as they won't be part of this problem.
Take care.
10 PCM
P0530HC
28 TCS
C1255H
60 IPC
B1543H
A1 RDCM
B2283H
B2285H
A0 LPCM
B2252H
B2284H
AS SCM
B0851H
B2860HC
Thanks again.
Sounds like you put in after market seats into your car and removed the SCM (Seat Control Module).
This may be your problem, it seems some vettes will not run right without the seat controller, My 2002 Z06 would not run without the drivers SCM plugged in.
If you run to run the aftermarket seats, you'll need to pull the seat controller and harness from your old seat and plug it in.
I would try this first.
Your active codes are for the seat controller and your A/C system.
Telescopic and Memory areas and missing SCM. I am assuming you have either a vert or coupe.
I would look into repairing this as this could be tha cause of your problem and it's the only codes that it is throwing.
I would clear your codes and see what codes come back. Electrical problems are sometimes tough to figure out.
How do you clear codes?Thanks
10 PCM
P0530HC - A/C no pressure in the system
28 TCS
C1255H - Internal fault in EBCM
60 IPC
B1543H - No oil temperature signal
A1 RDCM
B2283H - DCM voltage out of range
B2285H - DCM voltage out of range
A0 LDCM <--- Left Door Control Module
B2252H - Short to ground on door lock
B2284H - DCM voltage out of range
AS SCM
B0851H - SCM voltage out of range
B2860HC - Steering Column Position Sensor voltage out of range
Thanks again.
Do you know if the Column Lock recall (4006c) has been performed on the vehicle ??? Is the car an automatic or a manual transmission vehicle ???? Is the column "locked" right now (steering wheel cannot turn) ??? I'm going to assume it does not have a 3rd party "Column Lock Bypass" installed.
Finally, when you turn the key to ON (not START) can you hear any noise from the steering column ??
If your battery is even SLIGHTLY below full charge. the column lock error can occur. First thing I'd try is jumping your battery to a battery on a RUNNING vehicle (ensuring a good voltage level) then on your car insert key ... wait a few second ..... turn key to the ON position .... wait a few seconds (and observe DIC messages) .... then turn key to START if no DIC error messages in the ON position.
Let us know if that starts the car .....
That's why I thought he had aftermarket seats (i.e. SCM) error.
The car has a number of issues (EBCM shows a C1255 ...
) but the column lock appears to be the most pressing, let's try and get that one cleared first.
Time for a CLB. Had the same problem with my bro's FRC and had dealer do latest fix of removing steering column locking plate and reflash of PCM.
Thanks guys.
Thanks.
Thanks.
The reason I was recommending the jump for the battery is that the column lock system has proven to be VERY sensitive to even the slightest drop in votage ..... basically as you turn the key to ON and then START the BCM expects certain signals from the electronic column lock in a certain sequence and a certain period of time. If it does not "see" the expected sequence, it tells the PCM the column is locked, and the PCM shuts off fuel when the rear wheel speed reaches 2 MPH.
So, some folks have found two "tricks" to get the column to unlock .... one is jumping your battery to a running vehicle in the hopes that the voltage "jump" will allow the column lock to cycle correctly.
The other "trick" some people have found is when they get the key to the ON position, if the lock pin does not withdraw .... then fairly vigourously rotating the streering wheel left and right numerous times against the lock (basically "banging" the lock pin against the lock plate) in an attempt to "break it free" will allow the lock pin to withdraw. Listen for the sound of the pin withdrawing ... you will of course also feel the heel free up if the pin withdraws. Once it withdraws turn the key to START and the BCM should indicate to the PCM that the ECL is now "unlocked" and the vehicle will now run correctly.
If that doesn't work .... With the key ON .... delete the error codes in the BCM for the column lock .....B258x then turn key OFF and remove Fuse 25 from the Instrument Panel fuse block and leave it out for 10 minutes. Replace it and try starting the vehicle. Hopefully this will cause the column lock to unlock.
Once you get the column to unlock, you need to install either the GM Harness K which should be on the car, but it doesn't sound like it is .... is part number 89023816 and list price is $114.04, or you can order the Column Lock Bypass from this site ... $44.95
http://www.corvettesofhouston.com/index.php?cPath=29_42
The cheaper one is actually the more reliable fix. Order ASAP so this problem never bites you again.
Let us know how this goes ......
Take care.
