No start problem
Old Apr 1, 2008 | 09:44 PM
kloller's Avatar
kloller
Default No start problem
This morning the wife's 2000 C5 would not start. Basically it will not turn over. You can hear the solenoid click but that is it. I check the battery and it was 12.5 volts unloaded. I went ahead and put the charger on it unitil it was up to around 13. 8 Volts. Same problem. Tried jump starting it with my F250. Same problem. I looked at all the connections from the battery to the starter and could not find anything wrong. So I came to the conclusion that the starter was bad.
Installed new starter this afternoon SAME PROBLEM
It still just clicks. Ideas ? I put the battery on charge tonight and will have it tested tomorrow.
Old Apr 1, 2008 | 09:52 PM
jhong321's Avatar
jhong321
Is it a 6speed? if so check the clutch switch to make sure it is engaging if it is a auto try putting it in neutral.
Old Apr 1, 2008 | 09:59 PM
kloller's Avatar
kloller
Its an Auto. I had the wife put it in neutral back and forth to park this morning. I dont think the solenoid will engage (click) if the neutral safety switch is bad.
Old Apr 2, 2008 | 09:34 AM
busta's Avatar
busta
Could be the Theft deterrent relay, key, ignition s/w, or poor ground at the grounding block connectors or BCM? Try reseating the connections could get lucky.
Old Apr 2, 2008 | 09:46 AM
lucky131969's Avatar
lucky131969
Probably a good time to dig into the service manual troubleshooting before spending money on more parts that won't fix the problem.
Old Apr 2, 2008 | 09:50 AM
kloller's Avatar
kloller
Starter solenoid engages (clicks). This tells me the signal is getting to the starter it just does not have proper power to turn the starter over.
I think this means bad battery or connection issues with the power wiring. I'm going to take the battery and have it tested. I put a full charge on it last night. If good then I guess I start looking at all the power wiring and connections to the starter and engine gnds.
Old Apr 2, 2008 | 11:51 AM
kloller's Avatar
kloller
Car is fixed. Battery checked out okay. Removed an cleaned GND at engine block.
Removed both molded cable ends + and - at battery and remade connections with new battery terminals.
You can't see the copper wire inside of these unless you remove the molded part. Both had corrosion on and in them. Cleaned battery terminals.
Car now starts. Guess I should not have assumed and took a closer look at the wiring and voltage drops. Oh well car has 130K on it so a new starter did not hurt anything.
AC compressor has gone out so guess what I get to do next.
Old Apr 2, 2008 | 12:12 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
As Bill Curlee always sez.........check grounds Lots of electrical problems start with grounds. Congrats on the fix.
To No start problem
