Powerbond Crank Pulley Install
Car: ’02 Z06
Parts: Powerbond Crank Pulley+Acc belt
Gates AC belt
Gates AC tensioner
AC Delco AC idler pulley
Gates Accessory belt tensioner
ARP Crank Pulley bolt
Total Install duration: 5 hours
I followed the C5 heads/cam swap guide here: http://www.ls1howto.com/index.php?article=1
I thought I’d offer some advice for the install:
I took out the rack from the driver’s side instead. I still had to loosen the ABS controller mounting bracket. It was pretty easy to remove and re-install.
For the sway bar end link and tie rod end, you can use either a T-40 torx bit or a 6mm allen wrench.
I didn’t have to remove the power steering pump/pulley.
I didn’t have to remove the radiator.
I didn’t have to remove the alternator.
I didn’t have to remove the throttle body.
I had to spray some WD-40 between the pulley and the crank to be able to pull it out.
I used air tools which sped up the install.
Thanks to all who helped answer my questions in my earlier threads.
all the advice I have is in the original post. can't think of anything else right now.
