Code P0107
Old Apr 2, 2008 | 06:13 PM
Tomx64's Avatar
Tomx64
3rd Gear
Default Code P0107
Hi all I'm a newbie here. I removed my intake manifold using VECTORZ's post, to change my oil pressure sender and knock sensors. Now I'm getting a P0107 MAP/BARO Circuit Low Input code. Did I forget to hook something up ? At least I have oil pressure.Thanks
Old Apr 2, 2008 | 06:16 PM
LDB C5's Avatar
LDB C5
My bet is the small vacume line on the passenger side at the back of the manifold. Or maybe the MAP sensor is not seated correctly. The bummer is you have to remove the maniflod to get at them.
