I'm putting my car back together and I need to know how tight the rear axle nut needs to be torqued to. Thanks!
Are you referring to the "drive axle spindle nut" ..... the big one you can see on the outboard end of the drive axle when you first remove the wheels ... centered inside the brake rotors ?????
34 worked on my 99, but it was a tad bit loose. I'm sure that 33 is the correct size but I had to make do with what I had available. Thanks for the help guys!
Mike: take some anti-seize compound and apply a thin coating all over the exposed threads and the nut too. You'll be glad you did later.
