Cam change - Condenser out?
Old Apr 5, 2008 | 11:50 AM
vettezeke's Avatar
vettezeke
Default Cam change - Condenser out?
Do you have to degas the ac and remove the ac condenser to change the cam shaft?
Old Apr 5, 2008 | 11:52 AM
LinearX's Avatar
LinearX
No. With the radiator/fan assembly out of the way, you'll have plenty of room to move the A/C condenser around.
Old Apr 5, 2008 | 12:46 PM
Mike94ZLT1's Avatar
Mike94ZLT1
However you will most likely need a friend to gently lift the condenser and hold it out of the way, but you definitely don't need to remove any of that stuff. I pulled and replaced my whole engine without disconnecting any of that!
Old Apr 5, 2008 | 03:40 PM
vettenuts's Avatar
vettenuts
I put a pad over mine to protect it, but left it attached to the lines.
Old Apr 5, 2008 | 04:18 PM
jeanlucpicard's Avatar
jeanlucpicard
Yep...
Old Apr 5, 2008 | 11:56 PM
roysvett's Avatar
roysvett
Default just did it
I left mine conected removed every thing els no problems in with the new cam no issues
To Cam change - Condenser out?
